Due to a comedy of errors finally got my DR30 back on the road after nearly 9 months.
Fitted a new turbo and intercooler setup and took the car to a recommended workshop to have the Autronics unit fitted.
After the car being pushed out of the workshop every day for 3 months and sitting on a bush block with virtually nothing being done I took the car off them.
Another workshop took the project on and it took them 4 month to get the car running.
I've now spent 12 hours reassembling the car (why can't mechanics put covers etc back on when they're finished) and cleaning the car to get her back to where I had her.
What a relief that there is no long term damage to the paint after vitually sitting out in the sun for 3 months over summer.
On a more positive note the car drives great with 220rwhp which is a lot more than it had previously.
The tuner says the injectors are maxed out so changing them would net me a lot more power :banana:
I'll consider that but want to just enjoy the car for a while.
Missus thinks I have too many toys and wants me to sell to spend on and make room for my R33 GTR
3 cars and a Motorbike into a 2 1/2 car garage don't go :ermm:
https://www.sau.com.au/forums/topic/320823-dr30-back-finally/
OK thanks
One thing that was annoying me was that my car had a few pin dents in the rear guard and tops of the front guards.
Just got back from the dentmaster guy and I'm impressed!! Those guys are magicians.
Car looks fantastic
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
