R34 NEO RB25 starter / cas / injectors $249usd shipped to au
R34 RB25 & Rb26 top feed fuel rail $60usd + post to au
Rb26DETT intake plenum $289 shipped to au
Rb25DET S2 throttle body $60+post
$89+post to au
Stock cast Rb26DETT manfolds $60+pst to au
50+post to AU (RB26DETT oil Tee)
Porsche 968 Front calipers $389 shipped to au
R33 RB26DETT Bare block $599+ocean shipping to au
$179 shipped to AU.
pm or e-mail me [email protected]
https://www.sau.com.au/forums/topic/320923-rb26-rb25-parts-fs/
Brembo calipers $2800 shipped F/R set no pads or rotors
fenders $1500 shipped
door shell $1500 shipped
stock FMIC parts
headlights pair $1100 tab has been fixed
headlights 2nd pair $1300 for the pair
rear diffuser tray sides $150
door panels $1100 L/R side $1100
cluster pod $200
stock suspension $300
signal indicators $140 shipped
muffler $140 + shipping
center console $140 shipped
trunk and key fob slot $75
bose speaker and amp $140 shipped
  • 4 weeks later...
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
