Bonnet and hinges $165
Bonnet dampers $60
Guards L & R $110 (Passenger guard has a ding near the headlight)
The long metal parts the guards bolt to in the engine bay L & R $30
High beam L & R $75 each
Front bar $40 (Has a small crack near the passengers headlight can be welded, and the usual small scratch's)
Reo $50
Bonnet catch and support $60
Stockintake pipe with stock oil and BOV return pipes $40
Stock side mount with return piping $50
LHS passenger door COMPLETE, $90 (door skin is toast though)
$570 for the lot!!! (excluding postage and packing fee if going interstate)
Power steering reservoir $10 (can be used in pretty much any skyline though I think)
Auto trans cooler $15 (average cond)
Washer bottle with motors $20
Condensor $15
Stock horns $10
$40 for the lot!!! (excluding postage)
S15, came off at 60,000km's
Stock camber, traction and toe arms $40
Stock side mount with most if not all piping $50
Stock DIN pocket, hole cut in back for EBC wiring $20
Stock A pillar Garnish (no gauge cup) $30
$90 for the lot!!! (excluding postage)
Not a prob....
On another note, I'm going to put whats left onto fleebay... so if you think you might want or need something let me know and offer a price and lets see what happens. I need to get on with the backyard reno's
  • 1 month later...
Not a prob....
Paid for washer bottle well over a month ago and still its not arrived. Have sent messages and no reply. :D
  • 1 month later...
  • 3 months later...
Bonnet and hinges $165 NOW $120
Bonnet dampers $60 NOW $40
Guards L & R (Passenger guard has a ding near the headlight) $110 NOW $85
The long metal parts the guards bolt to in the engine bay L & R $30 NOW $25
High beam L & R $75 each NOW $105 FOR BOTH!
Grille with badges $60
Front bar (Has a small crack near the passengers headlight can be welded, and the usual small scratch's) $40
Reo $50
Indicators and foglights (front bar) L & R $25 each (Plugs have been removed but can still be wired up)
Bonnet catch and support $60 NOW $30
Stock airbox with panel filter and snorkel $80 NOW $70
Stockintake pipe with stock oil and BOV return pipes $40 NOW $25
Stock side mount with return piping $50!
LHS passenger door COMPLETE, bit dusty. Glass locks etc all perferct (door skin is toast though) $90!
Stock BOV $20 NOW $15
I'm at work quite alot of late and cant really answer the phone so please PM or txt me on 0409077592. Cheers
  • 1 month later...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
