Hi Everyone,
Im looking at taking out the engine and gearbox from the car and put it into a track car that im looking at buying.
The car is a 1994 R33 GTST sedan.
Everything minus the engine and gearbox will go with the car. The car has the r33 gtr wiring loom in it since it had an rb26dett in it.
The extras the car has is
BC Coilovers
Mags 18inch - MaxRSport
Slotted DBA 4000 rotors
Monza Racing seats
Kakimoto 3and half inch exhaust and highflow cat
The car has been well maintained and has been in the family for 7 years
Im looking for $6000ono
Car is located in Melbourne nothern suburbs
  • 3 weeks later...
Anyone still interested, if your after the car as in im open to offers.... 15k ono
If your after pic pm me and il be happy to send em
BUMP
Edited by 4drlvr
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
