Hi hows it going,
I currently have a Nissan Skyline r33 Series 2 gts-t, its got a few issues with it currently, it currently has a Front Mount Inter cooler, used to have a HKS Blow Off Valve but replaced it with the stock one. It has a 3" Full Exhaust, as well it has a Automatic boost controller however its got the display sort of smashed, so going to replace it soon with a manual one it as well has a turbo timer.
One of the issues is that its blowing black smoke and there and its leaking the black stuff from the exhaust onto the floor, also there is sense of a strong smell of petrol. My assumption its running quite rich, so im guessing could it be due for a tune, or it might be running too much boost but ive reved it ideling and it has been showing the 7 pound of boost. The car is currently unregestired however its never been driven, so dont if reving the car shows its real boost.
My 2nd question is, the oil is pretty much black, so would that mean its time for a oil change and oil filter change.
My 3rd question, is when sometimes its ideling it turns it self off so i was wondering could this be miss fires, or is it just due for a tune. Because im thinking maybe i need to replace the spark plugs. Also when its been slightly reved on a warm engine, sometimes it will shut off and wont turn back on until you give it about 5mins and it will start right back up. If i start it up straight after it will struggle to start up sort of like an old car.
If you could help me, it will be greatly appreciated.
Yours Truly,
Moz09
https://www.sau.com.au/forums/topic/321318-r33-skyline-problem/
Get the O2 sensor checked, most common cause of running rich.
Oil shouldn't be black, so definitely change that. I would personally change it anyway as you don't know what the previous owner had been using.
When you returned the bov to stock, did you plumb it back properly or is it venting to atmosphere? If it is venting to the atmosphere then that could also be the cause of the car running rich
sounds like you have a mild vacuum leak sumwhere, check all vacuum lines, intercooler pipes etc
if that fails, check your air flow meter (borrow sum1 elses and fit it to see if it still runs the same)
if that fails, post here again and ill keep thinking, theres lots of things i can list but some more obvious/easy things to elimate first before the not-so easy stuff has to be checked, like injectors etc
Sounds like a combination of running rich and a vacuum leak as snozzle said (I'd be trusting his opinion on this, he's a champ :devil: ) I'm wondering, when your car "dies/turns itself off" does it hunt for a bit before it does? By that, I mean do the revs at idle just start going out of whack and then stall? If so then I'd definitely say vacuum leak somewhere. If this is the case, you can use something like carby cleaner and spray it around the intake manifold and pipes beforehand, you'll hear if it is
Alright guys this is Moz09 however i have left the settings on my other computer which is out of use for now so using a mates account temporarily.
Anyways i found the vacuum issue as it was down to my boost controller vacuum line as it wasn't the right size one and was leaking, so ive replaced that now.
So this issue has been fixed, Ive as well done an oil and oil filter change.
However i still have stall's when its idling and its running rich still and still has backfiring issues when running idle, like you can actually feel the backfiring when your sitting inside.
Although I have thought about getting new spark plugs, but i don't want to chuck away money just yet, because i might not sure if new spark plugs will cause these stalls.
I haven't replaced the automatic boost controller yet, as i think it could be down to the automatic boost controller as sometimes the car wont rev past 2.5k and my mate told me its called a leap mode, so im going to replace it this week with a manual one and see if it fixes it.
However im still not 100% sure if it will fix the stalls, i am more interested in fixing the stalls currently rather then the car running rich and backfiring, however if you have any suggestions what could be the cause of the back firing and stalls as well it running rich.
Im guessing maybe the running rich issue is down to the ecu as i know the stock one does run rich but would the backfiring be the cause as well or?
I also have one more problem, sometimes when you actually let it warm up to like an operating temperature and you give it gas to about 4k, it will sometimes just shut off immediate would this be a cause of a another vacuum leak or misfire?
Hey hows it going, i switched today to the manaul boost controoler, im going to go tomorrow to buy some copper ones, however i eliminated the black exahust smoke problem as it was running quite a bit high boost before.
However i still tend to get a bit of a struggle around the 2.5k-3k mark when it comes to reving it as it will strugle to go past that so im guessing some sort of vaccum problem, however i looked at all the cables and intercooler piping and cant really find a leak.
Does anyone have any suggestions were i should look else?
I read somewhere about a small vacuum / airhose that used to go air box that if blocked, caused the car to to have a flatspot at the above rpm.
Try find a blocked hose or if someone else can elaborate cause its been 5+ months since i saw the thread with this info.
    • Let me assume that the concern over a manual ECU is that the NeoDET that you have was an auto and has an auto ECU. That ECU will not be a problem, but you WILL have to Nistune it. And you would have to Nistune it even if you had a manual ECU, because the turbo ECUs will shit the bed if they do not have all the things that they were told they have to have, to be happy. The big one being the TCS CU, which you won't have in your car. Anyway, with an auto ECU (which I have running my originally auto NeoDET in an R32) Nistune allows you to put in a Stagea image which doesn't panic about the absent TCS, and allows you to override a whle bunch of other annoyances that would otherwise see the check engine light on 100% of the time. Also, you can't wind up the power very far on the stock NeoDET ECUs without Nistune, because the boost sensor gets in the way. Nistune allows you to push that problem much further up the dial. Do you even have the boost sensor with the engine? Without it, you are SOL and will need an aftermarket ECU (or to find a sensor somewhere, god knows where). I can't tell you what the wiring loom differences are in a 34. But what Duncan said above needs to be considered. When you say "loom", does that include the transmission loom? Because you will need to swap out the auto tranny loom for the equivalent manual loom, and get rid of the neutral/park start interlock (basically hot wire it).
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
