have u got a front cut?
if so do u have the sensors for the a/c??
i have the one that fits in the front near the ash tray and the sunload sensor but i need the third one??
i have no idea what it is or where it goes but i desperately need it as its very hot at the moment and no aircon is killing me!!!
my a/c was working but i had a analog controller and replaced it with a later model digital one, the analog controller only had 2 sensors though and i need the third for it to work. because without all 3 the computer in it doesnt read porperly or something and it wont cool.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
