Cheers boys.
Sam, Using a D90. Is that white 32 yours? Are you using a fish eye for some shots or have I just not had enough coffee to function properly yet? :)
Rhys, If there's nothing like this in perth it just gives you a good excuse for a weekend away somewhere :P
I've just moved and got no net reception there :P i'll have to throw the rest on a stick and upload from here at work over next couple days. I was going to throw up some garage pics next.
Cheers boys.
Sam, Using a D90. Is that white 32 yours? Are you using a fish eye for some shots or have I just not had enough coffee to function properly yet? :D
Rhys, If there's nothing like this in perth it just gives you a good excuse for a weekend away somewhere ;)
I've just moved and got no net reception there :D i'll have to throw the rest on a stick and upload from here at work over next couple days. I was going to throw up some garage pics next.
No, didn't bring my GTR, rode in a friend's daily.
I don't have fisheye lenses, just an ultra-wide (11-16mm). Don't have any zoom lenses so couldn't do any track photography, still debating on Nikon or Canon :) WOuld be nice to get in touch with an interest group for photography for this sort of thing.
Edited by rocklee
Some nice pics 30-3 :D
Very ultra wide. Search around, I know there's a photo club or 2 in the riff. I've seen them all milling around the river a few times. If you don't find anything on here hit up the photography shop on high street and ask the little porn star who works there. He'd know for sure.
Here are some of my favourites from both days. Still got heaps to upload, so please check my website for further updates (blog post and a link in the gallery will be up in around about an hour).
Thanks,
Kory
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
