Cheers boys.
Sam, Using a D90. Is that white 32 yours? Are you using a fish eye for some shots or have I just not had enough coffee to function properly yet? :)
Rhys, If there's nothing like this in perth it just gives you a good excuse for a weekend away somewhere :P
I've just moved and got no net reception there :P i'll have to throw the rest on a stick and upload from here at work over next couple days. I was going to throw up some garage pics next.
Cheers boys.
Sam, Using a D90. Is that white 32 yours? Are you using a fish eye for some shots or have I just not had enough coffee to function properly yet? :D
Rhys, If there's nothing like this in perth it just gives you a good excuse for a weekend away somewhere ;)
I've just moved and got no net reception there :D i'll have to throw the rest on a stick and upload from here at work over next couple days. I was going to throw up some garage pics next.
No, didn't bring my GTR, rode in a friend's daily.
I don't have fisheye lenses, just an ultra-wide (11-16mm). Don't have any zoom lenses so couldn't do any track photography, still debating on Nikon or Canon :) WOuld be nice to get in touch with an interest group for photography for this sort of thing.
Edited by rocklee
Some nice pics 30-3 :D
Very ultra wide. Search around, I know there's a photo club or 2 in the riff. I've seen them all milling around the river a few times. If you don't find anything on here hit up the photography shop on high street and ask the little porn star who works there. He'd know for sure.
Here are some of my favourites from both days. Still got heaps to upload, so please check my website for further updates (blog post and a link in the gallery will be up in around about an hour).
Thanks,
Kory
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
