Hi guys,
After over 2 years building my dream supra, I have decided to stop the project and move on. I am looking for someone with a relatively stock r34gtr vspecII that would like to swap for my supra.
The supra has the following features:
EXTERIOR
Complete TRD wide body kit with stock front end an bonnet with MVP polyurethane lip (flexs and very hard to scratch)
moulded side skirts
custom dark grey pearl paint (based on the 997 porsche grey)
19x10 (f) 19x12 ® iforged billet 3 piece wheels (imported from the US for the TRD widebody)
late model headlight and taillight conversion
6000k HID head lights and fogs
late model clear indicators to front bar
ENGINE
RPS triple carbon/ carbon clutch (very easy to use and much more quiter than most clutches in the 6 speed gear box)
Polished everywhere
GT42r single turbo conversion
6 boost manifold
turbosmart 60mm stealth series wastegate
custom 3.5" dump
2 exhausts, super loud and exclusive HKS ti cat back and HKS super dragger
removable cat with cat delete pipe
1000cc injectors
044 intake pump
fuel rail
fuel reg with gauge
braided fuel lines
PHR racing catch can with nickle fittings and braided lines
relocated battery to rear hatch
fluyidine radiator
Greddy 4row (130mm thick) intercooler kit (now discontinued by greddy japan)
polished fan shroud and thermal fans
polished upper radiator hard pipe
black silicon joins
K&N air filter with polished 5" intake pipe
carbon fuse cover
carbon ignitor and cam cover
carbon front air diversion plate
polished billet dipstick, ignitor control cover, and otehr caps that also have supra script embossed into them
BRAKES AND SUSPENSION
Carbing aluminium front and rear strut bars with mater cylinder brace
HKS hypermax III coilovers
toyota big brakes (4pot, 2pots) with braided lines and slotted rotors
INTERIOR
utlra exclusive and very rare TRD dash panel set
Sparco milano bucket sets in black suede with bride low rails
brand new 6 speed gear knob
genuine carbon dash panels (also have a set of dash panels painted to match the car colour)
all black interior, including black genuine carpet and black vinyl roof
billet pedal set, gauge and gear boot surrounds
complete interior including roof, floor, door and hatch has been sound deadened with dynamat
Alpine 7" LCD pop up screen with ipod interface in glove box
rockford fostgate front and rear speakers
rockford p3 12" sub in moulded fiberglass boot install (still has room to put hings in the boot)
alpine PDX1000 amp for sub
alpine 2 channel amp for front speakers (rears run of head unit)
Im missing a few things and there is also a heap of stock parts to go with the car.
All mechanical work and tuning was completed by ESP racing here in Canberra. they also look after most of Canberra's supras and have their own 1000hp car. the car has made over 630hp on pump fuel however this has been detuned to a comfortable and reliable 500hp as the motor is not built. With a built motor this car will have everything ready to make over 900hp at the wheels.
The car has been driven less than 40kms in the last 2 years.
This is the perfect car for someone wanting one of Australias only TRD wide body supras. It has styling of an exotic car keeping many guessing to what it really is. Turns both young and old heads. The car has already been in the 'in the build' section of zoom and both zoom and HPI are waiting for the proffessional photos for it to be in their magazines.
It turely is a wonderful car. However, time moves and tastes and needs change.
I will post some pictures up soon. i have a project section on SAU and supraforums that have plenty of photos on the cars progress.
so...any takers?
Edited by natett
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
