Seriously, don't know where you guys are getting ripped off for $30 filters?!
Picked one up for precisely (note how accurate I'm being here) $16.95 and installed it in the dark in the carpark where my other one seemed to have died.
OP this should be in between easy and mind-bogglingly easy, depending on how much stuff you've got in your engine bay cluttering it up.
You're still going to pay someone?
This is depressing.
I remember a while ago, a guy on here had a window smashed, payed like $80 for the glass, and another $50 to fit it? something like that ... literally, 5 mins, in and out, tops...dunno how the f**k people justify spendings like that..
5 minutes to remove the broken glass and fit a new one!??!?
Dude if you can do that I can get you a job as a fitter anytime! In an 8 hour day I'll get 10-15 glasses done, depending on the jobs.
My boss will be stoked if you can punch out 96 jobs a day!
Less than 3 minutes!?
Are we using primers here? You're also assuming the guy has:
Olfa knife and blade
Glass primer
Body primer
Urethane gun
Urethane
You couldn't buy that lot for less than $50, and even if you could, you're assuming he's willing to do a job he may have never attempted
What I'm trying to say dude, is that you should get your boyfriend to change your fuel filter for you :D
He has a Boyfriend or u mean a Friend Boy??? Or he's Gay? Or just too gay to do it himself??
I attempted to do it b4.. not hard my Dad helped me.. 220bux def gettin ripped off unless u like that :)
Glass primer
Body primer
Urethane gun
Urethane
Wrong thread mayhaps?
I attempted to do it b4.. not hard my Dad helped me.. 220bux def gettin ripped off unless u like that :banana:
I am thoroughly convinced that you read through the entire thread to focus on if he has a boyfriend or if he's gay or not.
Fuel filters are piss-easy. Period. Unless they're intanks or something retarded like a late-model commodore with their weird locking clip things. By which you need Norma tools available, from your friendly neighbourhood Snap-On man (Ours is Chris Lovell).
I move for the thread to be closed because it makes WA sound like they've got 4 extra chromosomes.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
