  • Replies 174
aahhh, don't ask dude.
we were having disputes with the trubo supplier and when we came to an agreement, the dude from garrett said that he'll send down a A/R .82 which should be fine, but they actually sent down the A/R .63, and before i knew it, it was already on the car.
i think it should be ok though as the same combo with a A/R .63 made ~260rwkw on an RB30ET at ~20psi.
if i'm not happy, i'll be sending it back to sydney and asking for a .82.
That was a little bit of interesting information. Interesting being the amount of extra boost required for the SOHC head on the 3ltr to make 260rwkw.
you're cool dude.
i actually found out from my friend yesterday that the car i mentioned actually ran 18-19psi when it made that power.
also, another car with that same turbo made 285rwkw on 24psi.
i guess the SOHC makes quite a difference to power as compared to DOHC.
actually, my 2L cossie engine (DOHC) made almost the same power a VL RB30ET (SOHC) would make with the same turbo on the same boost, so i'm happy.
btw, the VL i mentioned which made ~260rwkw with the GT3040 (A/R .63) has run an 11.67@115mph at calder park, and fyi, it's a 5 spd manual.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
