  • Replies 45
http://www.highoctanephotos.com/motorvation
Congrats to Ant and SST, the trevs must be getting pissed... thats twice in 3 years a Jap cars won the dyno comp :D
And top work to Daze (XRW) for his burnout effort... short as it was...
http://www.highoctanephotos.com/modules.ph...lbum=44&pos=129
Ant's R32 GTR made 616rwhp, and took out the 4WD 6cyl blown, and I think outright class. Nathan Webbs R33 GTR made 475rwhp. I think Lee from SilviaWA got 400+ from his car too.
All-in-all a decent result considering the number of Trevs there:D
You mean "Lee from AFARCC got 436 hp" :-)
Eye witnesses said it was pinging it's arse off.... which usually suggests it wasnt tuned for the conditions.... given that it was cooler on the day than I was expecting... thats a surprise...
Anyone remember what it made on the dyno at Sport Compact? I'd expect them to be putting in a fair effort to get it back up to spec by the next Sport Compact....
From what i was told when Mr.X was tuning it (GT51R), he put the old 650hp map in, then when fine tuning it was arking out, and Mr.X goes, plugs are fowled, just change them and u wioll be right, and no furter tuning was done, hence is wasnt running right and not making power.
no need for names here.
i know Mr T hes hawt! ;)
has the engine been on to many dynos?... if it was pinging off its tits... then i wouldnt be able to hear it but i took a video of it doing the dyno and you might be able to hear it....i'll post it later on tonight if i can be phucked getting it off the camera ;)
i didn't hear nathans car pinging its date off, i did hear/see it wheel spin excessivly tho..
the was a fair amount of tyre smoke after the first run..
can anyone, ant hopefully confirm what gear they did the runs in, because his and nathans cars seem to come on very hard and very fast, a lot faster than i expected..
or is it just possible the new formax guy running the dyno, got the ramp rates wrong?..
Yea - I only saw Ant's run but couldn't believe the way it revved. As soon as it was on boost it hit the limiter! But would more load have made for less traction? Seemed with the dude sitting in the boot and the people in the car they still had issues with it..
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
