  • Replies 47
hey luke!
do you by chance have the squishy rubber hose that goes from the front turbo inlet elbow to the air flow meter/airbox? - think i can see it in the box in that pic you posted up
also wondering if you have the following hose?
http://www.skylinesaustralia.com/forums/post-a286350-
"14463MG" in the image.
oh, and a stock rear turbo oil drain? ;) AHEM.
If it's in the box Nigel ur welcome to it. Best to come down and have a look. I'm going all alloy piping so getting rid of all the rubber stuff I've got.
Luke
Whole list of parts for sale from my 1999 R34 N/A GT-four sedan.
Front seats $200 pair with rails
Rear seats $150
All seat belts $200
Parcel shelf with 4 tweeter holes cut out $50
Roof lining in black velour $150
All pillars in black velour $60
Fuel tank $250
Front bar $200
Front guards $ 200
Bonnet (couple of stone chips/pin dents $250
Bonnet latch $50
Bonnet hinges $50
Cusco Master cylinder stopper $80
Glove box $50
Kick panels $80
Door Trims $100
Cusco Full bolt in cage $1200
Brake master cylinder $120
R34 GT-four gear box, Small crunch 3-4. Chuck some redline in and she'll be right, Complete manual conversion $1200 Will include clutch master, pedal etc
Clutch pedal $120
Clutch master $80
Brake pedal $50
Accelerator pedal $50
R34 N/A brakes complete set, discs, calipers, lines $300
R34 N/A air box $50
All Air con stuff $200
Brake lines $50
Heater box (non leaking) $150
ABS module $150
Climate control display $150
Bnr34 brembo's low k's, slotted rotors, A1RM pads, braided lines, complete set $2800
R34 Rear hubs, handbrake set-up, handbrake lever, lca, $300
If your after a stock part that isnt there let me know.
Will be adding more as i think of it.
Cheers Luke
Hi there i'm after the hazard light switch for my r34 gtt sedan. Have u got it if yes for how much including postage to 3073.
Cheers :laugh:
hey mate your front bar standard?
sure is mate. It's got the factory fog light holes but the brackets were all rusted so took them out. Also got the little antenna in the front passenger area, but doesn't work anymore.
Also keeping the hazard thing as I may need it.
Edited by Luke_ENR34
  • 4 weeks later...
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
