Hey guys, got a little problem with my R33 S1:
Im using Q45 AMFs in my RB30 w/ RB25, they are connected through a Apexi SAFC-II to average the AFM value to the ECU, which have Nistune installed. The other day i was out driving when the BLACK/WHITE/SILVER DOTS +12V power cable to the AFMs got loose and shorted against a turbo causing the engine to cut out. This cable is also used for power supply to the SAFC.
I isolated the damage on the cable and changed the 10A 'Engine Control'-fuse which had burned and tried to turn the key and there was a buzzing sound from the passenger feet-area, my guess is either the ECCS-relay or the IGN-relay. Scratched my head, went a turn around the car checking the cable and tried again and it started.
Went home with the car, it was running as it should. Then when i tried to shut it off and the engine did but not the IGN-power, saw this since the SAFC-II is connected to that cable. I ended up taking the fuse out and obviously it died. Tried this acouple of times and it kept holding the power to the IGN, though when only if i turned the key in between.
Now to the weird stuff:
Tried to start it the day after and now when the key is in 3rd click the relay keeps the IGN power for the first time for 10 sec or so, then in some way 'restarts' and does this every 4th second. The car can start but shut down when the relay 'restarts'.
What do you think, a shorted wire to the relay? The cable i've been messing with is the BLACK/WHITE/SILVER DOTS going to the AFM. According to the wiring diagram it also goes to the crank sensor. Started the hard work ripping this cable out but i wanted to check what you guys think before i continue!
https://www.sau.com.au/forums/topic/322931-what-do-you-think-shorted-wire/
Thanks mate! I opened the ECU and smelled the board, could maybe be a very undistinct burned electrics smell, but not enough to make it obvious. Couldnt see any burned parts etc. either.
Since i've tried with the SAFC out of the picture, no luck,
I've split the loom and followed the AFM powercable back to the ECCS relay, looks fine but i've replaced it anyway, no luck.
Tried the ground and signal ground for the AFMs, no luck.
Tried a separate signal wire to the ecu, no luck.
Next step i guess is to try some relays from a mates car and see if it could be them after all otherwise i have no other solution then trying another ECU, but a Z32 ECU w/ Nistune does unfortunatly not hang from the trees around here :)
Another of those weird things are that if i dont have the AFM connected to the +12v ECCS Relay wire i cant connect to the ECU in Nistune.. Might have something to do with the 'Engine Control'-fuse that burned ealier, since it too comes from the ECCS Relay.. ?
Any tip is appreciated!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
