Bad health forces sale. Fastidious 61 year old owner is offering his beautifull R34GT-t at less cost than you could import and comply one for , if you are looking for a car that has never been modded out and is in in beautifull all round condition then this is the one you're looking for--
206KWS ATF from the factory and fully serviced up to and including it's majour 100000k timing belt one , everything which has to be replaced and or serviced has been including things like the water pump which aren't even service items ,
the complete serviceing on this car has cost over $2500.00. with receipts to show for all parts and labour , not just a service sheet from one garage where they may or may not have actualy done the work.
It also has all its Japanese log books and papers from new and I believe the 84400 klms is genuine.
It has the following minimal mods .
*Kingsprings OE ratio, 25mm lower than stock with all new OE struts.
*Turbo back custom exhaust- 3" dump 3" high flow cat 3.5" follower and mid muffler and 3'5" in 3'5" out Varex muffler, hard- -wired, isolator switched.
*Wheels / Rubber -- Stock OE 17 x 7.5 with Nexen 225 x 45 x 17 rubber 80% tread. -(can come with Enkei RPO3 17 x 8 --8.1 kg by negotiation)
*ICE-- Pioneer Carriozera DD head unit with CD, cassette and minidisc, works realy well,it has been adapter plug installed ---so the OE wiring is mint and I'm guessing that any new pioneer will likely be plug and play with this adapter.
* Drift airfilter * Tints *locknuts on wheels.
Everything on this car works as it should to factory specification ---and-- no rattttttles bbbbbbumps or gggggrinds.and the paint and interior are in excellent condition.
PRICE---$16490.00
Please pm or post to contact.
The car is in Helensvale/Surfers Paradise QLD.
Payment details--Cash or bank cheque on pick up or Bank direct deposit prior to pick up.
Could also be interested in trading for a BMW 318iS Auto Coupe or an FTO with cash adjustment my way.
**This ad cancels and supercedes any previously posted ad and price.**01/06/10
Edited by BASHO
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
