Hi there,
Just noticed a few days ago and only got around to doing anything about it now; while browing SAU on my iPhone with the default forum theme, as of somewhere near the beginning of June (not exactly sure), it displays differently (see picture). It was all running smoothly and looked good before then, and nothing has changed on my phone. All the other themes work as they should; just the default is thrown out.
Not sure if there's been a change, but I very much doubt it... Also there's something saying "Message closing in 2 seconds" displaying too. (top of pic)
Don't expect much to be done about it because I'm probably the only one with the problem, and there's probably not anything to fix... Just giving a heads-up.
https://www.sau.com.au/forums/topic/323492-iphone-and-ipb-220-default-theme/
  • 1 month later...
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
