If anyone has one, Ive got cash ready to go for the right price. I believe Ive got the standard PowerFC fitted into my s2 r33.
Cheers.
Will pref sydney so I can pickup but more than willing to trade with reputable interstate sellers.
https://www.sau.com.au/forums/topic/323551-powerfc-commander/
