hi for sale late 1995 r33 gtr v spec brembro brakes etc standard
colour black
km 101000
con very good
body mods has
full veil side body kit
18 by 9.5 star corp racing wheels
nismo rear spolier
tinted windows
drive train
exceddy hyper sensitive button clutch
dba 2 piece 8000 series front rotors with gold hubs
tein coil overs have standards as well
bolt on wheel spacers so wheels will clear brakes
engine mods
oramni built rb26 from the nismo factory
has new 50 mm alloy radiator
full 3 inch exhaust with quality front pipe
new gtr n1 steel wheel turbos
new intercooler
big injectors
after market fuel pressure reg
largest in tank walbro fuel pump
custom made oil catch can
twin pod filter setup with air flow meters removed
haltech full ecu with map sensor
alloy fly wheel
interior
pillar pod with greddy guages
centre pod with greddy guages boost oil temp water temp oil pressure
full auto touch screen dvd player
twin fusion subs in rear with fusion amp
after market speakers and tweaters
trust gear knob
greddy electronic boost controler
turbo timer
after market gear boots
genuine floor mats front and rear
car is a real head turner
in very good con in and out
have a dyno sheet for 332 kw at wheels car is currently running 290 kw for street use
NO TYRE KICKERS GENUINE ENQUIRIES ONLY
29 000 ONO WILL CONSIDER SWAPS FOR RIGHT CAR PLUS CASH
https://www.sau.com.au/forums/topic/323737-r33-gtr-vspec-with-mods/
colour black
km 101000
con very good
body mods has
nismo rear spolier
tinted windows
drive train
engine mods
new intercooler
big injectors
alloy fly wheel
interior
trust gear knob
turbo timer
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
