hey guys got my turbo for sale was on the car for 3 months and donr approx 3000km of use if that so just run in. never run over 7psi as i never got a tune before i stripped the car for paint.
full receipts from new 3k for the kit
polished housing
no shaft play
very responsive turbo makes good power with tune and injectors u can expect 260rwkw-280rwkw on around 18psi boost ecu and injectors
i also have a custom intake pipe made from stainless stell which is made to fit up to ur original r34 airbox and a custom screamer pipe made from stainless steel to suit gt3071r
i have spent my money to make this work beautifully and look stock. this is a straight bolt on kit no messing around.
reason for sale rb26dett going in the car :/
specs
GT3071R garrett ball bearing turbo
comp housing
0.50a/r
inducer wheel diameter 53.1mm
exducer wheel diameter 71.0mm
trim 56
exhaust housing
0.64 a/r
turbine wheel diameter 56.5mm
trim 84
peice 1.5k firm
Bob 0433696875
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
