Ok, So i am finally going to get my OS Giken twin plate (TS2CD) put in to my car. The existing clutch slips like a bitch, and when it gets some work in traffic, i get a grating feeling in the pedal.
When i get the clutch put in, should i look at upgrading the standard pivot ball to the nismo one, along with the pedal bracket.
What does the pivot ball do, i assume it interacts with the selector fork???
Also assume that he nismo pedal bracket is stronger?
Help and explanations greatly appreciated.
Thanks
Mike
https://www.sau.com.au/forums/topic/324497-clutch-pivot-ball-wtf-does-it-do/
to dis engage your clutch the thrust bearing needs to be pushed towards the front of the car .
your slave cylinder faces towards the rear
the fork acts like a see saw ontop of the pivot to connect the 2
Anyone have a view on whether it is worth $70 for a Nismo one or is the stock just fine?
just stitch weld the pedal, the one out of my 32 snapped like a carrot.
some people put a spacer under the piviot ball, lengthen the fork end and put spacers at the clutch slave to make it softer.
lots of things to think about
I've snapped a pivot, not exactly fun trying to rev-match a synchro box to change gears for 10km. Crash box on the other hand is fine :thumbsup:
For the peace of mind (especially with a heavy clutch), I'd put the Nismo pivot in while you have the box out.
Oh and I've had my Nismo pedal bracket sitting there for YEARS in anticipation of my breaking lol
Edited by bubba
Yeah, I've snapped 2 pivots (both R32 gearbox). Both times it also damaged the slave. The first time I drove home with no clutch, the second time the fork was wedged in the clutch jamming it half on, half off so when I tried to start it up & drive home it killed my clutch within seconds (was probably close anyway...) Felt like an auto with a high-stall...
Also snapped pedal box once, just got a new standard one & seam-welded it. In my opinion stronger & cheaper than Nismo.
As mentioned, for the sake of $70 get one & avoid any potential headaches
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
