Lads,
"Kris" busted my balls a couple times to do a build thread, a recent "where are they now?" thread on NS plus me being abit bored = ceffy members thread.
Short history:
Car was imported and was driven reasonably hard by softy and A31cefiro, copping a few hits,upgrades and paint jobs along the way.
Sort of knew softy years ago when he lived in Melbourne, was chatting to him one day and he proposed a price and said "bring ya towcar and trailer"
Price was decent, knowing the car needed some work I pulled the cash outta the bank and organised patricks autocare to pick the ceff up from his old mans work.
Car arrived, I slapped it together (turbo plus a few other things needed putting back on) then street skidded it.
Not long after, Organised rego (cheers phil!!) got a rwc for it, did more drift.
Got into abit of carnage and got slammed by another driftcar, resulting in front drivers qaurter damage.
Drove it with the damage for abit, more skids then got defected, yay.
Took it off the road, did rb25 and matching box convo, some more skids, had a few bugs to sort out, slowly sorted them out and then leaned out no 6 cyl, killing the 25.
Off the road again for motor and maintence.
Currently how it sits:
SPECS:
Bodywork:
vespa blue with gold pearl
flaired gaurds
series 1 rear bar
series 2 front bar with lip
"square" headlights (f**kin candles they are)
chrome grill
Wheels:
Bronze CST 17x9.5 +15 all round, 215/45 fedrals up front, whatever 235/45 rears.
Skidders: 17x9 +20 PIAA x4, 17x9 +17 and 17x8 +30 P1's
Suspension and brakes:
old as the hills JIC front coilovers
Captital D rear coilovers,
toe and camber arms, S14 front Lca's, s14 rack
strut braces
R32 GTR front brakes, rebuild calipers, aftermarket pads
Ceff rear brakes redrilled to 5 stud (going to r32gtst soon as i find a cheap enough setup forsale)
Interior:
old eastbear fixed back for drivers
r33 gtst passenger seat
unknown velour rear seat
full cage
momo ferrari edition steering wheel
omori gauges
Driveline:
R33 box,
NPC clutch with billet flywheel
Unknown ratio and brand 2 way Lsd
Motor:
(still not finished assembling the damn thing)
RB30det using a r33 RB25 head.
Mahle pistons
Spool rods
Crank grubscrewed
Block linebored and decked, bored to suit pistons, restrictors fitted
N1 oil pump with JPC gears
Ross balancer
VCT deleted
272 8.8mm lift cams with gears
reco head
rb20 front timing covers
IHI C7 turbo on a highmount trust manifold, trust wastegate.
740cc injectors
ebay copy greedy inlet
q45 throttle body
z32 AFM
Theres heaps of other stuff ive probably forgotten, will update as I change / fix stuff.
Will get some pics up of how it looked over the years aswell as some motor building pics.
Cheers,
https://www.sau.com.au/forums/topic/324855-street-bomb-a31/
  • Replies 73
As the Rb30 motor sits, picking up the head from the machinists tomorrow.
Just after It got smashed up, destroyed a gaurd, headlight, corner light and the rad support.
Abit pig looking, but still plenty of skids were done.
Will get a few more pics when I find em.
Cheers,
https://www.sau.com.au/forums/topic/324855-street-bomb-a31/#findComment-5298690
Vpw's shipment of ARP fastners got delayed, so it slowed motor build.
Ended up getting some headstuds off US ebay, hoping they arrived today, but nup.
Will get some more pics of the car next time im at my mates place (car is there, motor is at the old mans haha)
Only ceff related thing I have at home is the turbo.
Pic just for kris, other turbo is a 2871r.
Power figure? Who knows, 30psi should make things interesting.
Edited by works 510
https://www.sau.com.au/forums/topic/324855-street-bomb-a31/#findComment-5312700
Tensioner stud can be seen above the water pump in the above motor pic,
downloaded the "rb30det how to" guide located in the rb30 section but moved the stud 2mm to the left than what it says in the guide.
Also running two rb30e tensioners, price is cheaper plus a better final belt tension can be had.
https://www.sau.com.au/forums/topic/324855-street-bomb-a31/#findComment-5314485
Still no headstuds..... but picked up this last night:
redtop rb20.
Disregard those yellow rocker covers, just on there to keep water out.
Used this motor to grab most of the timing bits I need for my rb25/30's non-vct conversion
(Im using a R33 head, Ive done the internal vct supply mod and grubscrewed the oil gallery insted of welding it shut, just incase I want to run Vct again)
Some goodies include "RB20" embossed front timing cover :D
If anyone needs any redtop parts let me know ;)
Inlet cam is 248dur, small upgrade for silver top Rb20's. $50 and its yours :rofl2:
https://www.sau.com.au/forums/topic/324855-street-bomb-a31/#findComment-5320901
CST's are about 1600$ for a set, theyre becoming the new drifttek hahah
Heads on, have to get timing spot on yet and dial cams in.
Tried to mock up the inlet manifold up to the head, mounting holes dont line up :S
So its either modify again, or just buy a greddy manifold.
https://www.sau.com.au/forums/topic/324855-street-bomb-a31/#findComment-5326222
Still need to sort out some accessorys, coolant lines under the inlet manifold, fittings for turbo lines, and workout what to do with the vct/front oil drain line as the rb30 block has no threaded hole for it.
Most of the work is done tho,
https://www.sau.com.au/forums/topic/324855-street-bomb-a31/#findComment-5336222
motor is sitting on its mounts and its not going to fit under the bonnet without some mods.
First problem:
swaybar fowling the sump.
Worked out I have a s13 swaybar in it, and these touch the sump.
Scored a stock ceffy swaybar for $20 last nite, cant access the car today so I'll bolt it up tomorrow.
2)
greddy style inlet manifold hits the clutch master.
Either a R34 one will be used, or hopefully the engine mounts I make get the engine 20mm lower and under the clutch master.
Plan of attack for tomorrow arvo...
Bolt new swaybar up and inspect.
Re-measure sump to engine x-member clearance.
Whip motor out and pull the rb20 mounts off it.
bring them home and start making some mounts that will sit the motor lower in the bay.
Hopefully with lower mounts, the bracing trimmed from the bonnet and the rear of bonnet spaced up 10/15mm, the top timing cover and turbo will be under the bonnet.
Although having a hole in the bonnet for turbo and top timing cover, its not very practical for a street car, haha.
Also purchased a nistune RB20 ecu and some splitfire coilpacks for it last nite.
Pics to come.
https://www.sau.com.au/forums/topic/324855-street-bomb-a31/#findComment-5355727
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
