Decided to get around to stripping out my silvia
Motor, gbox, drivetrain and 5 stud are not for sale at this stage
stuff needs to go asap as i have no room and am storing most of this stuff at a mates..!!
Open to offers, worst i can say is no..!!
Call/ sms prefferd as i work long hours and dont always get near the computer to check pm's.
Car was a 1992 sunroof model sr20det.
Roof Lining $40
Rear seats $30 (sold)
Sunvisors $10 each
Cluster (sr20) $100
Type X 180 cluster $160
(I also have the plugs for this as I did a s15 dash conversion in a type x)
Cluster surround $30
Panel above driver knee’s $20
Center Console $30
Interior light (sunroof model) $20
Sunroof switch/ map light $40 (sold pending payment)
Digital climate control with loom $100
H/light stalk $60
W/s wiper stalk $60
Steering column plastics $20
Parcel Shelf $30
Ecu kick panel (has crack in it) $10
Glove box (i have two) $20
Seat Belts (front and Rear) $100
Rear side trims $15 each
Stereo surround $20
Driver side door trim (has a hole in top part) $10
Accelerator Pedal $20
Brake Booster $40
Bonnet release cable $30
Washer bottle with washer motor $20
Heatbox with good core $30
Heater fan box $30
Air con box (under dash) $30
Caster rods with near new bushes $140
Rear view mirror $15
Various plastic ducts from heater to dash vents $5
Std s13 horns $5
Sr20 engine bay loom (goes from behind left headlight to driver side of dash) $150
Boot seal $20
Door seals $20
Std front and rear sway bars $40
Castor rod mounts (goes between caster rod and rad support) $20
Complete sunroof setup minus switch $200
Lh Indicator $30 (have two of these)
Sr20 stainless extractor manifold $100
S14/ s15 strut brace (was on my s13) $80
S14/ s15 turbo intake snorkel $30
Also got these parts suit 1jz soarer from when I was gonna put a motor in my mx83.
wiring loom $150
ecu $100
ignitor $60
front sump (suit Cressida etc engine swap) offers
jzx81 cresta headlights (mint condition) $250
Im located in melb. Parts are either in heathmont or moodialloc.
vic buyers only at this stage as i dont have much time to get to post office atm.
Cheers, brad 0437 198 210 (if i dont answer i will get back to you asap)
pics avaialble on request. too many to upload. can either mms or email.
I also need a few r32 gtst parts like fuel tank and straps, coilovers, gtr front bar lower lip. so im open to trades of parts with cash adjustment.
https://www.sau.com.au/forums/topic/325088-s13-silvia-stip-out-sale/
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
