<<<<<<<PRICE DROP TODAY 16K>>>>>>>
hey got my r32 up for sale! has had heaps of coin spent on it over the last 3 years ive owned it...makes sweet power with the hks 3037 gt pro turbo! spoools hard by 3500rpm and holds till 8200 :D will b sad to see it go but now im looking for a lil more of a cruiser! so ne one thats interested plz dont hesitate to txt me and ill tell u more about this crazy machine!
mods:
s1 rb25
acl race series pistons rings bearings
npc built clutch
stainless manifold
hks 3037gt pro s turbo with braided oil lines
hks 50mm gate with screamer
respray morpheous purple
advanti chrome voltz 18x8
viva garage full kit
carbon vented bonet
vi-pec ecu - with custom loom
coilovers tein coilovers
front mount
shimed diff
drift catch tank
aftermarkt FMIC
flared and rolled rear guards
front(mines) and rear(whiteline) strut braces
slotted front roters and new bendix pads allround
boot sprayed black with boot holes bolted up :(
brand new windscreen
rear seats removed - but will come with car
momo steering wheel
greedy gear nob
euro style carbon mirrors with LEDs-not wired in
clarion dvd touch screen headunit with splits in front and 6x9s in rear
greedy turbo timer
2xdrift guages
3inch exhaust - no cat - and abffle removed from cannon...insane note!!
will come with spare standard plenum, 2x15 inch spare rims(no tyres) standard rb25 ecu, standard steering wheel
also has original mats
. makes 288kw on 15psi :( this tune was done as a quick safe run in tune around a year ago for powercruise and havent needed to touch it since!
one bad point is that the teins may need replacing. am looking around for a new set as we speak.
looking for 16k(neg) or may swap for VTEC CIVIC/CRX with cash adjustment. cheeers andy g. txt me for pics 0400341730
HAS JUST HAD HEAD RECONDITIONED-EXHAUST GUIDES< VALVE STEM SEALS, VALVES, NEW: ehaust,intake,head,rocker gaskets (under100km ago)
Attached thumbnail(s) img-resized.png Reduced 77%post-55077-1275024274_thumb.jpg 640 x 480 (85.36K)//img-resized.png Reduced 77%post-55077-1275024288_thumb.jpg 640 x 480 (84.74K)//img-resized.png Reduced 77%post-55077-1275024304_thumb.jpg 640 x 480 (78.16K)//img-resized.png Reduced 77%post-55077-1275024320_thumb.jpg 640 x 480 (92.67K)//
img-resized.png Reduced 77%post-55077-1275024410_thumb.jpg 640 x 480 (76.2K)//img-resized.png Reduced 77%post-55077-1275024425_thumb.jpg 640 x 480 (85.36K)//
https://www.sau.com.au/forums/topic/325165-89-r32gtst-rb25-hks-3037-gt-pro/
  • 3 weeks later...
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
