hey,
Considering selling my r32 as it just sits there and i need money for a few things atm..
its pretty standard except isc coilovers all round, bn sideskirts and rear bar, standard front bar.. turbotimer.. 18x9 & 18x9.5 impul chrome wheels (work equip copies)
roof is dented from a fiberglass bonnet opening while driving.
interior is stripped and backseat removed as was gonna get roof fixed but now have other things to pay for, have all interior bits there. also have a spare roof with sunroof sitting there which i was gonna use to replace dented roof... was gonna cost bout 2000 to do the roof swap i think from memory.
bit of an EOI atm so pm me offers if interested...
Adelaide..
Edited by corey70
https://www.sau.com.au/forums/topic/325273-r32-adelaide/
hey mate i am pretty keen on this car, do you have a number i can reach you on to discuss further?
i can be contacted by email at [email protected]
Edited by Chaos Theory
https://www.sau.com.au/forums/topic/325273-r32-adelaide/#findComment-5305018
forgot to add it has fmic (as u can see), 3" exhaust i think its a veilslide or something, and a hks ssqv bov...
located down south of adelaide, woodcroft/morphetvale area..
phone no; 0401 451 377
had quite a few pm's.
Not interested in swaps as the only reason im selling is due to financial reasons...
cheers,
Corey
https://www.sau.com.au/forums/topic/325273-r32-adelaide/#findComment-5306262
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
