Hi
anyone here using a vg30 turbo? if so does anyone have an aftermarket down pipe ?
and or does anyone know where to get them? im hoping to get one with a screamer pipe?
iv got a guy that can make one but the issue is that he is not sure how to seal the air between the wastegate and exhaust.
any help?
im aware of the of the legalitys so please dont post on here about it!
https://www.sau.com.au/forums/topic/325382-vg-30-downpipe/
there are 5 different VG turbos, post up some pics and that will help a hell of alot more.
How so this make any diference to the exhaust rear housing that concerns the dump or downpipe???
It would be a real shame if we stuck to subject huh!
https://www.sau.com.au/forums/topic/325382-vg-30-downpipe/#findComment-5315425
And I have had 4 VG30 turbo's here, 3 with diferent casting numbers on the compressor housing, but all with identical exhaust outlet flange pattern.
I had one Hi Flowed which I still have and never used and gave the others away or swapped them for bits I could use later on.
I also have an R34 NEO turbo and that has the same flange pattern as the VG30.
D
https://www.sau.com.au/forums/topic/325382-vg-30-downpipe/#findComment-5322614
