Hi All,
My car did a strange thing this morning, i had just left the house and was about 1km down the road at the intersection when as i accelarated it cut out twice but picked up again almost instantly as i took my foot off the accelarator. I wonder what could be the cause as it was fine for the rest of my journey.
Has anyone experienced this?
Cheers Richard
https://www.sau.com.au/forums/topic/325442-cutting-out/
This sounds similar to a problem I had a year or so ago.
The Fault was the Cam sensor on the right bank. It was a recall item in Japan has also been a problem on local Pulsars that use the same cam sensor.
My car would literally stall at any speed and would have to restart the motor.
This ma not be the same as it sounds like you car is not stalling but it does sound like the computer is cutting the engine because it detects some sort of fault is shutting down ti protect the motor.
Good luck finding the error
Cheers Andy
https://www.sau.com.au/forums/topic/325442-cutting-out/#findComment-5300554
Cheers Andy
Hi Andy,
Thanks for the heads up, so did you have to replace the sensor?If so can you remember any part numbers and what the cost was.Did you need to reset the computer or does it sort itself out once you start up?
Thanks again cheers, Richard
https://www.sau.com.au/forums/topic/325442-cutting-out/#findComment-5300847
  • 4 weeks later...
Richard, did you find the problem. My car started doing the same thing two days ago. Under load, it would suddenly cut the ignition but then come good again. I can drive it forever on a light throttle and it doesn't happen, but accelerate or climb a hill and it gives these almighty coughs. It's too savage to be a fuel problem, and too savage even for just one HT lead or plug. It's a total (but momentary) ignition cut.
It may not be the same as your problem, but it sure sounds suspiciously like it.
Cheers, Jeff.
https://www.sau.com.au/forums/topic/325442-cutting-out/#findComment-5351454
Hey Jeff,
sorry i haven't had the problem again, what you explaining sounds exactly the same good luckand if you don't mind keep me posted.
Thanks Richard
Well, the diagnosis is a dead (or at least very sick) Crank Angle Sensor. My Auto Sparky did a great job. It took someone with all the right diagnostic gear, which is defintely not me. It now behaves like it should - like one of the best motors in the world! :thumbsup:
Cheers... Jeff.
https://www.sau.com.au/forums/topic/325442-cutting-out/#findComment-5356995
Thanks Richard
Well, the diagnosis is a dead (or at least very sick) Crank Angle Sensor. My Auto Sparky did a great job. It took someone with all the right diagnostic gear, which is defintely not me. It now behaves like it should - like one of the best motors in the world! :P
Cheers... Jeff.
Hi Jeff,
I'm glad you found the problem, was it a matter of giving it a clean or was it a bad connection with the plug or did the sensor just give up the GO? What was the damage to your pocket for the job?
Cheers Richard
https://www.sau.com.au/forums/topic/325442-cutting-out/#findComment-5359525
The crank angle sensors fitted to the VQ35DE & VQ25DET were subject to a Nissan recall because of a high failure rate. There should be a round silver sticker on your car on the drivers upright and this indicates that the car was inspected by Nissan for the recall.
The same crank angle sensor was used in Nissan Pulsars imported to Australia of the same vintage and they had the same problem here also.
Just one of those small hassles of importing.. but so worth while when the motor is going well.
https://www.sau.com.au/forums/topic/325442-cutting-out/#findComment-5359678
Richard / Andy
Sorry for the slow response. I must have a profile problem because I never get notified of postings.
The damage was $290, including $165 for the part.
Cheers... Jeff.
Hi Jeff,
That sounds like it was resonable price, thanks
Cheers Richard
https://www.sau.com.au/forums/topic/325442-cutting-out/#findComment-5362910
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
