I just picked up an R33 gtst s2. It needed a new diff and radiator so I've just finished replacing those and today I just noticed a slight whirring noise, which I think is coming from the timing belt cover.
Has anyone had this noise before? It only does it just off idle then it's fine after that. I've already ordered a new timing kit and water pump today which I'll fit on Friday, and hopefully that fixes it.
The motor has done just over 100,000kms so I'm gonna play it safe and replace the belts and pulley, and water pump while I'm at it.
https://www.sau.com.au/forums/topic/325911-is-my-timing-belt-on-the-way-out/
100k service = change timing belt. you're due so change it, interference motor means things get ugly if it snaps.
aftermarket belts eg gates make some noise anyway, but if yours hasn't been done and it's the OEM belt then it could be a warning sign that you should change it!!
i never heard a peep out of my OEM belt, got a gates on there now and it does make a slight whirr just off idle but they often do that.
Yea I'm prayin it's only the timing belt. I bought the car off a mate and he was straight up with the few things that were wrong with it and he did mention the timing belt hasn't been done yet. The motor sounds perfectly smooth, only the slight whirr just off idle. My parts should get here Thursday, so I should have it all completed by Friday arvy. I'm massively keen to get it on the road but don wanna playin Russian roulette n end up blowin the motor by drivin it with the old belt.
Hey guys, I am having the same issue ....HOWEVER,
my 96 R33 GTST (100km covered), was due for a timing belt, especially as I only just got the car a few months ago and didn't know if its been done.
I bought a timing kit, had it fitted, and within 2 weeks I am getting a whirr/growl from top of timing cover,
the noise only happens a few hundred RPM over idle and goes when revved higher, I have noticed that the growl goes once its warm (after a few mins) but have also notice when quite hot... I am getting a high pitched groan/moan from the same area.
Is the idler bearing shot? or tensioner? or is it just a noisy belt?
My other concern is that the tensioner has been set too tight and its worn the bearings ... is this possible?
Note, The noise wasn't there before the timing belt was done. :down:
Muchly appreciated if anyone else can shed some light?
Andy
New belts usually do that before theyre settled in, If it's a Gates timing belt, completely normal, might need retensioning down the track if it still does it
So a little growl just above idle for a few minutes is normal?
will it quieten down with age? Is this the same for the hum/whine when it is warm?
Thanks
so, i changed the timing belt yesterday and changed the tensioner and idler pulley while i was at it. The water pump was weeping out of the 'tell tale' hole so i replaced it as well.
It would have been approximately a 4 hour job, but my mate that was helping me accidently snapped off one of the 6mm bolts that holds the top timing cover on. Then it turned into a big mission to find a small enough ezi-out kit in town. And in the end I ended up drilling out the bolt and tapping it to an 8x1.25 hole instead and now its all sweet.
Anyways, now the new belt is fitted, the whirring noise that was there before, is now completely gone :-)
There is now the higher pitched whining/whirring noise... which is obviously characteristic of a new timing belt until it runs in.
But other than that, everything looks fine.
  • 4 weeks later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
