  • Replies 83
why?
is there pix of your girlfriend?
if not then i'm staying right here hitting the refresh button every five mins waiting on this hottie here.
...any minute now. =P
Sorry I thought I signed up to a forum about skylines?? hmmm...
Yes it does contain pics of my girlfriend..... shes white and seexxyy :(
https://www.sau.com.au/forums/topic/325953-oh-hai/page/4/#findComment-5347542
im with eps on this one mutha f**ka.
u in the wasteland broah, yeah it might be a sub section of the wasteland but u still here aight
Need an english translation for some this? haha.
I'm new so only just finding out what the "wasteland" is :(
https://www.sau.com.au/forums/topic/325953-oh-hai/page/4/#findComment-5348686
I'm new so only just finding out what the "wasteland" is :D
just f**king with u man
the wasteland is where we come to play lol
welcome to the forums aight, ur car looks nice mine used to look like that lol
https://www.sau.com.au/forums/topic/325953-oh-hai/page/4/#findComment-5350005
jaylon - finding out what the wasteland is...
picture a land with rolling planesand views as far as the eye can see.. everyone is a road scholar, involved in community programs and sporting events, everyone gets along and has a nice time, there is no crime, no wrong doing..
everyone smiles and waves at everyone else, the infrastructure in this land is incredible, everything runs smooth, there is green manicured lawns EVERYWHERE within the urban metropolis. everything is perfect. this land you're imagining... is skylinesaustralia.
even the grassed area where people meet and greet to network.
well... it LOOKS perfect. but on that grass... smack bang in the middle of it.
is this big fat pile of steaming thick dark brown streaky sloppy cow shit.
and crawling throughout this disgusting warm pulsating mess. is about 50 or so dung beetles... all fighting each other over trying to eat the little bits of shit. these dung beetles don't play fair either. if one dung beetle is eating a bit of shit that another dung beetle wants. that "have nots" will eat the legs off the "haves" it's a disgusting filthpile that should NEVER be entered.
we are the dung beetles. and that pile of cowshit is the wasteland. and you were a fool for posting in it.
I'm Rowan. Ice to see you.
https://www.sau.com.au/forums/topic/325953-oh-hai/page/4/#findComment-5350074
:) Sorry i fell asleep halfway through....
haha I joke, sounds very interesting!
They tricked us newbies into posting in the wasteland by having an intro section in here!!!!
.....meh
https://www.sau.com.au/forums/topic/325953-oh-hai/page/4/#findComment-5350534
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
