Hi,
Just installed new rb25 engine (after rebuild) with rb26 bottom end, wiseco forgies and HKS 256/8.8 in/ex camshafts.
The car idles with vacuum gauge reading ~ -0.43...-0.45 kpa which seems a bit low (usually ~0.6). I know that aftermarket cams can bring the vacuum down -- is this figures ok?
The second problem was that after initial ignition and fuel pressure tuning the car idles quite lean 17-18 AFR. Vacuum leakes where not found... Can cams cause this?
Have the cams been dialled in, that vacuum isnt too bad, as it sounds like it hasnt been tuned yet. When you say ignition and fuel pressure tuning, what do you mean exactly? Stock ecu?
the cams was installed with stock camgears -- so they have not been dialed in with a special procedures. as i read in this forums tomei poncams give the best result in default position. hks have very similar to tomei figures so i assumed it`s true for hks too.
ignition tuning is rotating the CAS with a ignition light to get 15 degrees on the crank pulley at idle.
fuel pressure tuning was setting the base fuel pressure at sard fpr (it was brand new and was set to 4 bar instead of 3bar -- but with 4 bar the idle was better).
ecu is power fc.
Tomei grind their cams at a lobe centre angle that is optimum for their bigger duration to give the right amount of overlap, this allows you to use stock cam pulleys. The HKS cams are ground to standard lobe centre angles, with increased duration the HKS items will be causing too much overlap hence the worse vacuum and the need to dial them in with adjustable cam pulleys.
ok, i understand how to dial in exhaust cam as it is possible to install adjustable cam gear on it, but what to do with intake camshaft -- it has nvcs gear so it can not be adjusted...
intake is adjustable fron the factory . take it out and look at the back of the cam gear or get one of these
http://www.trademe.co.nz/Trade-Me-Motors/C...n-293718049.htm
i read somewhere years ago it can be difficult to set mixtures at idle with big cams.
however, ur cams arent too aggressive, it may need further checking with the afr's u mentioned.
if its a stock computer ur kidding urself expecting it to run like this :thumbsup:
rb26 bottom end? changed stroke/cc etc? this will also not help the poor old stock ecu if thats whats still running(trying to run) it.
it`s not stock, it`s power fc as i mentioned before, so it`s not a big problem.
this is not true, please see the follwoing links for comparison:
Tomei Factory Camshaft Specs
HKS Camshaft Specs
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
