hi, i hope someone can shed some light for me.
1. if i took my 25 head to be ported what would be done?
2.if i were to die grind the inlet bigger to the valves would i be increasing flow for better or worse. (like using to big intercooler pipes)
3.for each cyclinder there are two valves (as you know), the inlet splits into two, if if I were to grind the split down so it was one would that increase flow or would it create turbulance?
Cheers Tim
Depending on what sort of power you decide upon leave most of that 'porting' alone.
If the head requires a reco' then just get the combustion chamber bowl area cleaned up a little. The radius on the stock head aren't too bad. The intake and exhaust ports might like a bit of smoothing to remove cast imperfections although the ports themselves even with 'the bumps' will still flow a large amount of power.
With power of the order of 450hp or less the rule 'ain't broke don't fix it applies' and you even save time and money yay!. With the die grinder you can smooth things off but, without experience in matching the ports evenly don't try to increase the size of anything.
Hi guys, I keep hearing the "RB ports aren't too bad standard" line. Well I reckon they are pretty average really, lots of dags, casting marks, misaligned manifolds, thick and protrusive valve guides etc etc.
The turbo engine story goes "don't worry about the porting, just turn the boost up some more". Well I don't subscribe to that, I'd much rather make my power target at the lowest boost possible. So by porting, polishing and matching I might be only able to save say 0.1 bar, but even that is worth it. I can run higher static compression, more ignition advance and the engine will build boost faster because it flows better.
I have a rule, if I take a head of one of our engines, I ALWAYS get it ported, the manifolds matched and internally polished and equalised combustion chambers .
As the Rev said RBVS, if you are doing it yourself, remember less is better. It is so easy to take too much out, and remember you can't ever put it back.
Hope that helps.
I totally agree with Sydneykid. The SR/RB heads still have alot of potential with them. After all, they were designed with stock power levels in mind.
Even just a quick polish/degag/match port, there is definitely some gains to be had with a small amount of effort!
ok cool , i was thinking just a clean up and a polish. i can see were the gasket sits and there are marks (black) , ring around the the openings which i was thinking of cuting back as in let air and exhast gasses must be hitting.
mite be important to match inlet but exhast and turbo manifold bigger you can get em the beter or what?
i will be doing my self, but will take great care, not going to go nuts
what was the result with the head mambastu? (power wise?) ;)
I haven't actually fitted the engine to my RS13 yet. Should be going in the car in a couple of weeks time with various other goodies on it so I'm not going to be able to give a 'before and after' result I'm afraid.
When I've run it in I'll post up the dyno results and we can speculate how much power I've gained (or lost :) ) from it :)
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
