just doing head gasket atm, and their is coolant lines everywere on rb's.
Im sure you can do without many of them, i know def the tb one does not need to be connected.
But anyone else out their blocked any up before or know which i can block up ?
Any info muchly appreciated.
+1 for leave them
sure people will tell u u can make more power etc without coolant running through everything, but if bits r cold on the intake ur car will have bad fuel atomisation etc and might drive like a pig till warm. remember carby cars often run a heat riser tube off the exhaust manifold to the intake for this reason.
reminded me of the "mod" where u bypass the throttle body coolant hoses etc and people feel a gain in response and power etc! lol kinda odd considering the whole inlet manifold has coolant running through it!
hehe, at least ur doing it for logical/sensible reasons :)
as for getting rid of em, yes its a mess under there, and its been a while since i had a good look with a plenum off, might have to try and nut it out, or just change all the hoses to save headaches.
i had one in there let go, it was an absolute prick to change!
When I had my head off I redid some of the coolant lines by removing some and reconnecting others. It's a bit hard to describe it all but the easiest one to do is the throttle body coolant one and rejoining it elsewhere. That's one line you can piss off, don't need to worry about a buterfly sticking shut in Australia's climate.
I have had many let go over the years on my other 20's. its bullshit, And i really think they are not essential.
I will replace them all new if no1 knows, but i have heard of people removing/blocking a few.
Maybe because of the age of the lines, or becoming blocked?
What would nissan not know that you do?
This is about as far up there with mods such as filling the chassis rails with foam, or looping the battery fumes into the intake...
Battery fumes into intake?! :) rofl
Please ellaborate!
Kinda reminds of me of a wrx owner i was on the phone to, who wanted his ""screamer pipe" hooked up to the intake to his turbo"
Yes epic LOL
I explained u only do that if u want a nice fire in the engine bay and kindly suggested to bring it past and i'll have a look what he meant exactly what we might be able to do for him. He never turned up tho funnily enough! :(
Generic foam in chassis rails wont do squat, but u can get stuff more specific for the job that does apparantly work, off topic either way.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
