hello can somone tell me what the tourqe setting is for conrods-- fsm is 15nm then 60 degrees, thats a crap way of doing it, fair enuff on head bolts but. bit risky on rods. some say 40ftp on mains and same on rods,, 40ft pound? is alot for rods. anyone?
its holding me up in my rebuild. thanks guys
Factory rod bolts and main bolts 50nm for both.
FSM says torque in kg/cm2 or something....nothing about 60 degrees.
If you have aftermarket rod bolts/rods or main studs then these settings will be different
cool thanks. seems to be alot for the rod bolts tho? this is what i have in fsm---14-16NOm (1.4-1.6kg-m) mark with white marker and turn 60-65 degrees. ??? told have to turn in degrees as bolts tend to strech a bit.. i was going to tighten to say 20ft pd,, but u think 50 ftpnd. can i ask how u got tht,different manuals?
when you have the torque wrench in your hand and and you click 50nm onto that rod bolt, tell me then that you think it feels like too much. I reckon it feels like not enough. But it's not a matter of how many nm or ft/lb required, it all comes down to bolt stretch. If you have a stretch gauge, torque them down til you see 0.006 stretch and that will be spot on.
sounds bloody good to me, ill go and finish her off. . all my other motors,long as theres bit of movent all good, ill let no how they feel .
Also I have run this on two RB25 engines that still used factory rods and bolts and they are both over 80,000k old without issues
yes thats tru. they do lock once load has been applyed ,started. so it should be 36ft p
thts good because i done big ends at 35ftp
Edited by cuztomr33
yes i have built diesels to 202's to sr20's.few other types,plus bikes 38models to 2000.
when i said movement i ment, once tight, you should be able to still move rod foward and back a bit. all good sumps on.
What do you mean by movement, torquing the rod bolt shouldnt effect bearing clearance.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
