Got some wheels and tyres for sale:
4 x black wheels, 2 x 17x8 with Federal RS-R with heaps of tread, 2 x 17x9 with no tyres. $400
3 x ROH 17x8 wheels with Federal 595 235/45 R17 93v - one tyre goes flat regularly but the other two are fine. I was going to use them for drifting, never got around to it. $50
2 x Falken Ziex 265/35 R18 93w, no tread only good for drifting. Free.
2 x Kumho Ecsta 265/40 ZR17 96w, have tread but heaps old so only good for drifting. Free.
2 x Michelin 270/65 18 and 2 x Michelin 240/64 18 Porsche Cup slicks. Past their best but still way grippier than street tyres and cheaper too. Fit's on 18x8-8.5 and 18x9-9.5 rims. $150
2 x 18x8 disgusting chome rims with Falken Ziex 225/40 ZR18. Bugger all tread. $50
0421 301 061
Cheers.
  • 4 weeks later...
  • 3 weeks later...
Still got some wheels and tyres for sale - prices dropped:
4 x black wheels, 2 x 17x8 with Federal RS-R with heaps of tread, 2 x 17x9 with no tyres. $300
2 x Michelin 270/65 18 and 2 x Michelin 240/64 18 Porsche Cup slicks. Past their best but still way grippier than street tyres and cheaper too. Fit's on 18x8-8.5 and 18x9-9.5 rims. $100
2 x 18x8 disgusting chome rims with Falken Ziex 225/40 ZR18. Bugger all tread. Free
0421 301 061
Cheers.
  • 1 month later...
  • 2 months later...
No ones wants? All free now.
  • 2 months later...
You have PM
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
