I got the following parts for sale
Item 1:
Pulled out of
R32 GTS4. aftermarket shocks and kings springs in excellent condition
Price and Condition: $60
Contact Details: Pm me here in SAU or email me on [email protected]
Delivery & Conditions: Pick up only (Can be posted @ buyers expenses)
Item condition : Used
Item 2:
Door trims came off R32 GTS4, will fit R32 GTS and GTS-T. It has some marks as shown in the pictures and both trims have 1 hole each to suit a tweeter install
Price and Condition: $30 pair,ONO (will not sell separate)
Item 3
Used: Autometer Boost Gauge Sport Comp Mechanical with Auto Meter Gauge Cup (Black)
Vaccum/Boost Product # 3401
Size 2 5/8" (66.7mm) Type: Mechanical
Range 30 In. Hg.-Vac/20 PS
And also a 2 5/8" Auto meter Gauge cup (in black)
Note: Boost gauge dont come with the hose but has the cables for the bulb of the gauge, Good condition as it was on my Skyline working fine.
In ebay they selling the gauge alone for $99 no postage
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...IT#ht_500wt_928
and the gauge cups for $29 no postage
so grab a bargain, why buy a new one? if a used one works excatly the same.
Price and Condition: $60 for both gauge and cups
Item 4
FORD 4 Channel Amplifier
Price and Condition: $50 ono
Item 5
Soundstream 2channel Amplifier
GREAT LITTLE TWO CHANNEL AMP WITH PLENTY OF GRUNT THAT CAN EITHER RUN SOME FRONTS OR REARS OR CAN BE BRIDGED UP AND RUN A SUB AND AT THIS PRICE CAN'T BE OVERLOOKED.
HERES THE SPECS
Max Power @2ohm 420w
RMS @4ohm 80x2ch
RMS @2ohm 95x2ch
Bridged RMS 195w
Soundstream SPA-1002 420w 2ch Amp
Features :
-Full Mosfet Power Supply
-PWM Circuitry.
-Full Selectable Crossover Hi/Full/Low
-Three Way Protection Circuit
-2ohm Stable Stereo
-Tri-Mode Capable
-Variable Low Pass 40Hz-250Hz
-Variable Hi Pass 150Hz-1.5Khz
-S/N Ratio:98 db
-System Distress Indicator
-High/Low Level inputs With Floating ground
-Spade Terminals
-Top Chrome Plate
-Platinum RCA Connectors
-Line output.
RRP $299
link is here :http://www.trademe.co.nz/Trade-Me-Motors/Car-stereos/Amplifiers/2-channel/auction-280819226.htm
Price and Condition: $120 ono
Item 6
BOSS AUDIO CAP2B 2 FARAD CAPACITOR WITH DIGITAL DISPLAY (Near New)
When heavy bass notes in your music hit, the current demand on your system greatly increases and could cause voltage drops. This stiffening capacitor acts as a power reservoir, instantaneously supplying added power to keep your system playing strong.
-2.0 Farad Digital Capacitor
-Colour: Black
-Digital voltage level display
-Chrome finish terminals
-Includes mounting brackets
-20V DC
-24V Surge
-Dimensions (without mounting brackets): 10-1/2"L x 3"W x 3-1/4"H (laid flat)
Mounting Bracket is included. What you see on the picture is what you get.
CAPACITOR WEIGHS AROUND 2kg
This is $120 RRP, For you only
$70 why buy a brand new if works the same.
Item condition : Used (Near new condition)
Used APEXi AFC Neo Piggy Back ECU
Reason of selling: Chipped ECU
Condition: Good condition
Description:
The SAFC NEO marks the newest edition to the world famous Super AFC line of piggy back fuel controllers. Building upon the powerful SAFC II, the AFC NEO has taken piggy back style fuel control to a new level. The AFC NEO boasts an incredible 16 points of user definable fuel correction. VTEC control has also been incorporated for Honda/Acura applications. A complete monitor mode is also available to keep the driver/tuner informed of critical engine data.
Features include:
Completely new case design
Compact design
Incorporates both AFC and VAFC functions in one unit
16 point fuel correction
Color FED display
User defined button and background colors
Inverted "anti-glare" screen
Key functions include:
MONITOR MODE-
RPM
Throttle
Battery voltage
Correction %
Air flow %
Pressure
Karmann
VTEC
SETTING MODE-
Air map
Air map graph
Throttle point
Deceleration air
VTEC control
VTEC unmatch
ETC MODE-
Model select
Mode select
Car select
Sensor select
Analog scale
Warning set
Display set
Sensor check
CONCEPT:
High resolution fuel control with integrated VTEC control.
CHARACTERISTICS:
Revolutionary color FED display easily customized by the user.
RRP:$800 SAU members $300
Reference:
-http://www.apexi-usa.com/products/?id=5347
-http://www.modyourcar.com.au/apexi-afcneo-p5022
Pics Below:
Price and Price Condition: $300
Contact Details:PM here in SAU or email me on
[email protected]
Delivery & Conditions: Pickup only/Can be posted at buyers expenses
Item Condition: Used
https://www.sau.com.au/forums/topic/326662-r32-partsampsshockstrimsecugauge/
is it all 4 shocks and springs or just the pair??
interested if set of 4.
hi,
the rear shocks are in full set
but the front only has the struts without springs, i will throw that one for free..
let me know if ur keen
cheers
oh and if they are fronts will you seperate and sell just the shock? willing to pay the same amount
hi,
I do have the front, without springs,
they are same brand of that yellow one
the front one i have without spring
its pedders front shock/strut
let me know if ur keen on this one
cheers
i hav sent u a pm
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
