Hi all,
Got some fibreglass eyelids for my 34 and have had insane amounts of difficulty painting them;
1.Sanded them down, wiped clean with wax & grease remover, applied grey acrylic primer which sticks perfect.
2.Apply black acrylic gloss spraypaint and as soon as the paint hits the surface it appears to 'bubble' and seperate
3.When looking at the surface dried the whole surface has an orange peel look and some parts have small bubbles
I have now tried doing this probably 10x or more and have had no luck, have tried wiping with metho rather than wax and grease remover, have tried in different temperatures, have tried placing the can in hot water to warm paint, have heated up the back of the eyelids with a hairdryer to warm the surface before hand etc.. I have also taken the surface right back to fibreglass with thinners and tried all over but no luck..
I cannot workout what the variable is that allows the primer to stick fine and not the paint (all the products are acrylic).. Everything I've researched indicates a contaminate but I've had no luck. Also tried 3 different brands of paint, even tried sanding the black bubbly paint back in hopes of hitting it with clear to bring back a smooth gloss but then the clear does the same thing!!
Please please any advise is appreciated I'm going mad for something I thought would be straight forward.
cheers,
Steve
https://www.sau.com.au/forums/topic/326753-trouble-painting-eyelids/
how long are you waiting between primer and top coats? are you wiping them with wax and grease remover between primer coats and top coats? are you sanding the primer before applying the top coat?
Yeh you should be spraying the base coat paint before the primer actually dries. The thing with primer is it soaks into the material, so you have to put quite a lot of primer on until you can clearly see that it isn't being absorbed anymore. And then you want to spray the base coat before the primer dries so that they chemically bond. You shouldn't need to sand unless you are fixing something like a run, or the layer has gone completely hard and the layers need to be physically bonded rather than chemically.
Your problem sounds like either silicon or the paints are attacking each other which is pretty common when you use wax & grease remover. I advise you start again. Completely remove everything with paint thinner, get rid of everything on it until you can see the base layer. Now do a REALLY good job of cleaning it, and even lightly scuff it with 600 grit sand paper. You need to make sure there is absolutely no thinners left on it. Now spray the primer again, doing what I said so you can see that it is no longer being absorbed into the eyelids. Primer is pretty forgiving, you can use a lot of it. Once you are happy with your primer coats, apply the base coat paint just before the primer is touch dry. This will allow the primer and the paint to chemically bond to each other. Do the same thing with your clear coat if you are using any.
Feel free to check out my album of things I have painted http://www.facebook.com/?ref=home#!/al...d16373c642972e1
Edited by Hanaldo
Due to the number of times I've done this and tried to eliminate the variable causing the problem. I have done the top coat within maybe half an hour (touch dry) of the primer coat. I also initially tried sanding the primer coat, using wax & grease remover then doing a top coat but both have returned the same result.
thanks for your reply =)
Hey Mate,
Really appreciate you taking the time to give all this advice. I will go grab some thinners from Bunnings (and more paint i've nearly run out =< ) strip it back to the fibreglass and start over.. You mentioned not using wax & grease remover are you saying to just clean it with thinners and wait for it to dry then do primer>top>clear without sanding in between?
Also you mentioned the top coat and clear coat before they are dry so should it all pretty much be one process?? (ie: primer coats every few minutes apart followed by black followed by clear)
thanks again.
Hey Mate,
thanks again.
Don't let thinners dry on the fibreglass, will cause the problem all over again. You gotta make sure you really clean all the thinners off. Plenty of water, and a fairly good rub down with 600 grit will get rid of it all.
Yes, should all be pretty much one process if possible, don't sand between coats unless you get a run and you need to let the paint dry to sand it off. If you get the layer perfect, move onto the next layer before it dries. So you spray the primer, will probably take about 5 coats before it stops soaking in, and then spray the black, then the clear. You want to let the layer underneath set a little bit but not go dry before you spray the next layer, if you get that lol? Probably won't even take 5 minutes.
A good way of doing it is if you are spraying the eyelids on some newspaper, use the oversprayed paint on the newspaper as an indicator of when to do the next coat. When it is a little bit sticky still, but not wet, that is when you want to spray the next coat. Just before touch dry.
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
