hello, i have a problem with my s1 r33 skyline. It has a pod filter, front mount intercooler and 3 inch cat back exhaust apart from that i think everything else is stock.
when i start driving in the mornings or when the engine is cold everything is fine, makes good power all the way to 7000 rpm but by the time the engine has got to normal operating temp it feels like its misfiring from 3000 to 5000, then is ok to 7000rpm. Even driving normally under light throttle it will feel like its misfiring as soon as the revs get close to 3000. It has new plugs gapped to 0.8 and brand new coils (superspark) and the injectors have been cleaned and tested.
would really appreciate any help or advice
https://www.sau.com.au/forums/topic/326819-desperately-need-answers/
OK first off, I'm going to ask wtf you're revving it to 7k when it's not up to temp?!
Then, I'm going to suggest igniter or coil harness, check with known good items. My temp. related misfire issues were due to the plastic inside the coil plugs deteriorating and falling apart.
So it is running the stock ECU?
With those same mods I struck the failsafe "rich and retard" that the stock ECU is programmed to run. Same symptoms were observed.
thanks for the tips. i pulled the coil harness out and one of the plugs fell apart in my hand so i need to repair or replace that item. any ideas where to buy the connectors or a complete harness???
That's exactly what happened to mine. I had an electronics mate I used to work with at the automotive R&D place try to track me down the plugs but to no avail :D
rhdjapan.com has complete harness
That's where I got mine from except I could only get an RB26 one at the time.
Justjap has them aswell, for all models it seems.
  • 3 weeks later...
i found some connectors and repaired the wiring harness (n16 pulsar with the 1.8 litre motor has the exact same connerctors) but still no change. it has a stock ecu and is running stock boost so i am starting to lean towards a management issue. whats a cheapish way around the problem as i am planning on selling the car and don't want to spend mega bucks on something that im not going to use but i still want it to be fixed properly
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
