  • 3 months later...
Hello to all.
Had a look around here and thought i might aswell join up after picking up a c210.
Trying to get a mate to join up as well that owns a hr31.
Anyway here are some photos of the old girl,i get her home on the weekend so will have some better photos of it then.
picture 2
picture 3
picture 4
Nice coupe, very lucky to find one these days, i own 3 c210,S 2 sedans, and one coupe same colour as yours,
your one is a 1979 model, believe me mate... mine are restored and you need really to love them, it will cost a packet.. my coupe is JDM,
rare in australia,
Hope i can be any assistance if you need anything,
Cheers
https://www.sau.com.au/forums/topic/327076-hi-all/#findComment-5476641
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
