As of july 1st there are some new finable offences and massive fine increases. Some interesting ones I thought I would inform you of are below.
It's now an offence to smoke in car with a person under 18 present. $239. I would expect a lot of these could/would be issued and a lot of unhappy smokers.
Another interesting one is Offensive behaviour by a person in a motor vehilce (only in St kilda) $119
Drunk in public place is has gone up to a massive fine of $478, offensive behaviour is now $478 also. Big night out could become very expensive if you don't behave.
I wouldn't be surprised if they have an operation "quit" campain to target driver's smoking in above circumstances.
https://www.sau.com.au/forums/topic/327176-interesting-new-fines/
  • Replies 76
wow.. thanks again graeme. i went out last night and i noticed last night a massive Drug test setup and lots of NOU's near toorak rd/ chapel st. a commodore gets pulled over and defected and a skyline gets let through! whats the odds? lol
never seen so many cops out on a wednesday night
This makes me wish I was under 18. I hate it when people smoke while I'm in their car.
You shouldn't smoke in your car without consent of all passengers anyway. That's just common courtesy.
All those laws are harmless though. Just don't be an idiot. Plus less time spent smoking means less cancer anyway :D
Edited by jezza boii
Even if these are revenue raisers atleast they are out there for a better purpose than vehicles and their modifications. In particular I like the drunk and offensive behaviour in public fines. Hopefully alot of these get handed out to trouble makers. Also smoking in a car under 18 is probably a good one.
About f**king time. It should be illegal to smoke in a car FULL STOP. You can't eat, talk on a phone, sms, read, drink so WHY can you smoke.
ummm you can eat and drink in a car? I smoke in cars, tbqh it's no more distracting than adjusting the volume on your stereo, perhaps they should ban those too? (goes hand in hand with then offensive use of a motor vehicle thing LOL)
Yeah not sure, perhaps Graeme can clarify. I think it falls under effectively controlling the vehicle.
What I meant was, it takes 2 seconds to adjust the volume where as smoking you've got something in your hand the whole time, you have to find it, light it, smoke it then butt it. Not a 2 second job.
Smokers will disagree but shit hey!
passive smoking is filthy sh*t lol
Agreed.
I wish they'd make a public smoking ban already. I'm sick of gagging when walking down the street or into shopping centres. Children/babies have to breathe that in too!
Until they provide smoking areas that are 'undercover' as well, I'd have to disagree with that one. - us smokers are people too :) It's bad enough as it is that we can't even stand under a covered area regardless of how high the ceiling is :D
There was that guy who got a fine for eating a Mars bar i think last year?
Great laws, smoking in cars should be banned i reckon. Sick of people asking me "can i have a smoke" while i am driving, i say no and they beg and beg till i can't be bothered putting up a fight. Ban ban ban! (Sorry if you read this Carlo and Fatty) <3
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
