Hey Hey,
I have heaps of Skyline gear i have collected of the years! i have R32 and R33 S1 and S2 Stuff and if i havent advertised it, just ask and ill see if i have it or if i can get it for you. Cheers Ty
#1 R33 Series 1 spoiler (black) $80 ono
http://www.nissansilvia.com/forums/index.p...ttach_id=280322
#2 Unknown Brand Cannon $50
http://www.nissansilvia.com/forums/index.p...ttach_id=280342
#3 Apexi BOV (ok condition, gr8 sound) $60 each (got two)
http://www.nissansilvia.com/forums/index.p...ttach_id=280323
#4 Series 2 two door tail lights and rear garnish $150
http://www.nissansilvia.com/forums/index.p...ttach_id=280346
#5 Rear RH quarter panel (gd condition, white) $250
#6 Series 2 dash (ok conditon) $100 ono
#7 Rear Hicas unit $60
#8 R33 fuel tank (gd condition) $80 ono
#9 Passengers Side Mirror $60
#10 Drivers side door with glass $80 (gd condition)
http://www.nissansilvia.com/forums/index.p...ttach_id=280344
#11 Drivers and Passengers door trims (gd condition) $50 each
#12 Indicator/Wiper Assembly $40
http://www.nissansilvia.com/forums/index.p...ttach_id=280347
#13 Front hubs (LH and RH avaliable, 5 stud) $60 each
#14 Front Assemblies (knuckles and upper arms) $60 each
#15 Rear seat (ok condition) $50 ono
#16 Complete S2 RB25DET engine loom (includes injector loom) $150
http://www.nissansilvia.com/forums/index.p...ttach_id=280350
#17 Complete Dash loom $30
http://www.nissansilvia.com/forums/index.p...ttach_id=280352
#18 Petrol Flapper/door $10
#19 Rear 2 door interior quarter panels $40 each
#20 Brand New r33 front and Rear King Springs $300 the pair
#21 Windscreen Washer Bottle $20
http://www.nissansilvia.com/forums/index.p...ttach_id=280336
#22 Set of 17"x7" rims (good tires on 2, other 2 need replacing), $600 ono
minor gutter rash but overall pretty good, (will not fit over large brake calipers)
#23 Digital Climate control Unit (r33) $50
http://www.nissansilvia.com/forums/index.p...ttach_id=280351
#24 Accelerator Pedal and Cable $40
http://www.nissansilvia.com/forums/index.p...ttach_id=280354
#25 Boot lid and petrol cap Cable $15
http://www.nissansilvia.com/forums/index.p...ttach_id=280356
#26 Set of 5 seatbelt for an R33 S2 $50 (gd condition)
#27 Steering Column with Barrel, Key and Trim surrounds $120
http://www.nissansilvia.com/forums/index.p...ttach_id=280357
#28 Hks SSQ (gd condition) with rb25 adaptor $70
#29 Front RH and LH Guards (White in colour and gd condition) $120 each
#30 Reo Bar for behind R33 S2 Dash (Straightand good condition) $50
#31 R33 Engine Crossmember $50
#32 R33 Stock Airbox and Snorkel (gd condition and gd filter) $80
#33 Flywheel and Bolts $80
#34 Extreme Heavy Duty Clutch and Pressure Plate (gd condition, hardly used) $100
#35 R33 Brake Booster and Cylinder (no plundger) $50
#36 Glove Box from a R33 S2 $40
#37 R32/33 Stainless Steel Intercooler piping $100
#38 Manual R33 Brake Pedal $30
#39 Heater core/Unit from an R33 $40
#40 SRS Passengers Airbag, S2 Steering Wheel with Airbag and Airbag Module $make an offer$ (not activated)
#41 S2 Pink Label AFM $110
#42 Stock Rear Bar for an R33 (need respray) $40
Just ask if u need anything else, send me a PM, ill see what i can do.
Cheers Ty
https://www.sau.com.au/forums/topic/327363-garage-cleanout/
Hey Hey,
Cheers Ty
Don't suppose i could get some pics of the R32/33 Stainless Steel Intercooler piping?
https://www.sau.com.au/forums/topic/327363-garage-cleanout/#findComment-5331830
Hey Hey,
Cheers Ty
do u haev the interior panel for quarter windows?
plz email me at
[email protected]
interested
https://www.sau.com.au/forums/topic/327363-garage-cleanout/#findComment-5332314
  • 1 month later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
