Hey Hey,
I have heaps of Skyline gear i have collected of the years! i have R32 and R33 S1 and S2 Stuff and if i havent advertised it, just ask and ill see if i have it or if i can get it for you. Cheers Ty
#1 R33 Series 1 spoiler (black) $80 ono
http://www.nissansilvia.com/forums/index.p...ttach_id=280322
#2 Unknown Brand Cannon $50
http://www.nissansilvia.com/forums/index.p...ttach_id=280342
#3 Apexi BOV (ok condition, gr8 sound) $60 each (got two)
http://www.nissansilvia.com/forums/index.p...ttach_id=280323
#4 Series 2 two door tail lights and rear garnish $150
http://www.nissansilvia.com/forums/index.p...ttach_id=280346
#5 Rear RH quarter panel (gd condition, white) $250
#6 Series 2 dash (ok conditon) $100 ono
#7 Rear Hicas unit $60
#8 R33 fuel tank (gd condition) $80 ono
#9 Passengers Side Mirror $60
#10 Drivers side door with glass $80 (gd condition)
http://www.nissansilvia.com/forums/index.p...ttach_id=280344
#11 Drivers and Passengers door trims (gd condition) $50 each
#12 Indicator/Wiper Assembly $40
http://www.nissansilvia.com/forums/index.p...ttach_id=280347
#13 Front hubs (LH and RH avaliable, 5 stud) $60 each
#14 Front Assemblies (knuckles and upper arms) $60 each
#15 Rear seat (ok condition) $50 ono
#16 Complete S2 RB25DET engine loom (includes injector loom) $150
http://www.nissansilvia.com/forums/index.p...ttach_id=280350
#17 Complete Dash loom $30
http://www.nissansilvia.com/forums/index.p...ttach_id=280352
#18 Petrol Flapper/door $10
#19 Rear 2 door interior quarter panels $40 each
#20 Brand New r33 front and Rear King Springs $300 the pair
#21 Windscreen Washer Bottle $20
http://www.nissansilvia.com/forums/index.p...ttach_id=280336
#22 Set of 17"x7" rims (good tires on 2, other 2 need replacing), $600 ono
minor gutter rash but overall pretty good, (will not fit over large brake calipers)
#23 Digital Climate control Unit (r33) $50
http://www.nissansilvia.com/forums/index.p...ttach_id=280351
#24 Accelerator Pedal and Cable $40
http://www.nissansilvia.com/forums/index.p...ttach_id=280354
#25 Boot lid and petrol cap Cable $15
http://www.nissansilvia.com/forums/index.p...ttach_id=280356
#26 Set of 5 seatbelt for an R33 S2 $50 (gd condition)
#27 Steering Column with Barrel, Key and Trim surrounds $120
http://www.nissansilvia.com/forums/index.p...ttach_id=280357
#28 Hks SSQ (gd condition) with rb25 adaptor $70
#29 Front RH and LH Guards (White in colour and gd condition) $120 each
#30 Reo Bar for behind R33 S2 Dash (Straightand good condition) $50
#31 R33 Engine Crossmember $50
#32 R33 Stock Airbox and Snorkel (gd condition and gd filter) $80
#33 Flywheel and Bolts $80
#34 Extreme Heavy Duty Clutch and Pressure Plate (gd condition, hardly used) $100
#35 R33 Brake Booster and Cylinder (no plundger) $50
#36 Glove Box from a R33 S2 $40
#37 R32/33 Stainless Steel Intercooler piping $100
#38 Manual R33 Brake Pedal $30
#39 Heater core/Unit from an R33 $40
#40 SRS Passengers Airbag, S2 Steering Wheel with Airbag and Airbag Module $make an offer$ (not activated)
#41 S2 Pink Label AFM $110
#42 Stock Rear Bar for an R33 (need respray) $40
Just ask if u need anything else, send me a PM, ill see what i can do.
Cheers Ty
https://www.sau.com.au/forums/topic/327363-garage-cleanout/
Hey Hey,
Cheers Ty
Don't suppose i could get some pics of the R32/33 Stainless Steel Intercooler piping?
https://www.sau.com.au/forums/topic/327363-garage-cleanout/#findComment-5331830
Hey Hey,
Cheers Ty
do u haev the interior panel for quarter windows?
plz email me at
[email protected]
interested
https://www.sau.com.au/forums/topic/327363-garage-cleanout/#findComment-5332314
  • 1 month later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
