Sup, as described in heading,
Before I go to Nissan sourcing 'new' parts, figured someone's wrecking some of these random items. All for R32 GTR.
1x Headlight Switch Assembly. I may also take the whole fascia that surrounds the cluster.
1x Battery Cover. "If" they help hold the battery a little more still. I have the clamp but no battery cover, so only sheer clamp force will hold the battery firm.
10x Floor plugs. (The ones you will find holding your boot trim to the car)
The parts that sit in the door trims to hold the 4x6" speaker in place. Namely the speaker mounts, anything that stacks on top of them, and the "active speaker" stock speaker covers.
1x Spare wheel (can come in the form of a radial with no tyre, mainly after the rim)
1x Spare wheel cover.
1x Drivers seat adjusting lever. (The plastic handle)
1x Centre console fascia. Gloss black. (The plastic surrounding the radio/climate/centre gauges) - Ashtray and lighter optional.
1x ABS Unit. (The solonoid block near the turbos)
PM any costs + delivery to 2259.
Thanks in advance.
https://www.sau.com.au/forums/topic/327597-lf-r32-gtr-parts/
Thanks in advance.
Hi mate give Erwin a call i know he Wrecking complete R32 GTR so im sure he got all the parts you need.
0410069096 or sms him.
pretty sure i have one, will get back to ya
** EDIT: is this what you are after?
I haven't taken it out yet so I dont know what it looks like underneath, but that looks to be the part yeah. Does it work properly? Mine turns only one light on, the maybe the other if it wants, taked 100 goes to get both lights on. I heard the lights run off the switch without relays, so I'll be wiring up a set of relays this weekend to save the next switch a bit.
How much if it's good mate?
Interesting you say that, I just bought a rear seat off him and thought he rorted me! Lol but it's ok it came through today, I was worried cause of another issue we had bout 12 months ago when I received some faulty stuff, which he since replaced free of charge. I'll give him a call anyways, thanks!
I have the ABS Unit here ready to go
$150 plus delivery from perth
PM me if you want or msg me on 0422 648 745
Thanks Daniel
Hey Daniel,
The prob with mine is it's leaking, spoke to a few people and they say it's rare for them to leak? So I must ask the question for the record, does yours leak? :ninja:
Thanks all who are helping me out.
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
