Evening all,
I've got a 260RS and was curious to know if anyone else out there has gone down the road of fitting a set of 19" rims?
I've had a look at all the numbers and this is what I know so far from looking at the original C34 16" rights through to 18" and now 19".
C34 205/60P/16" which gives a rolling radius 204.96cm's total diameter 65.24 Sidewall height 12.3
My current 18" 235/40/18" gives a rolling radius 202.7cm's total diameter 64.52 Sidewall height 9.4
Just curious to know if anyone else has done this and whether the suspension is likely to suffer with the lower profile tyre.
The other thing that gets me is the C34 sticker has two sets of numbers, the lower numbers are below, to me that's saying either the front and rear are different or you can select either or tyre choice for the stock rims - the latter seems more probable but then again the BBS rims on the 260RS were different sizes too. That said I'm currently rolling on the same sized 18" wheel and tyre. Any help for someone who is trying to work things out for themselves is greatly appreciated!
C34 225/50/16 I put that into a calculator and got a rolling radius 198.36cm's total diameter 63.14 Sidewall height 11.25
The C34 numbers came from here: http://www.skylinesaustralia.com/forums/St...ons-t92233.html
https://www.sau.com.au/forums/topic/327637-19-rims-vs-18-bs-stock/
I run the suspension and rear cradle width as a 260rs
My rims are 19x9.5 +12 with 245/35/19 tyres
Just make sure the rims are "A" disk (at least on the front) so they clear your brembo brakes
What ever tyre size you pick, the only important thing to maintain is the SAME rolling diameter front and rear. Keeps the AWD system happy.
don't do this if you are buying work rims.
each manufacturer has different 'codes' for disk types
ie your volks are A-disk (maximum caliper clearance) and clear your brembos, but if you bought an A-disk wheel from work wheels you would get standard caliper clearance in their range and they would not clear the front brembos - you would need R-disk which is their term for caliper clearance.
just make sure whatever wheels you get, the fronts have adequate clearance for big brakes. the rears it doesn't matter (unless you want to rotate front to rear for tyre wear)
i'm also running the narrower cradle in my stag which is also fitted with r33gtr brembos and i have 18x9.5+2 R-disk (maximum caliper clearance) fronts and 18x9.5+1 O-disk rears (minimum caliper clearance, maximum dish). probably on the extreme side of fitment though :ninja:
Just re read my message - was in a hurry on my way out to a touch game.
The link that works....
Also, with offset I read this from the same link above from Sydney Kid
"The only Stagea S1 with 17" rims standard I have seen is the 260RS. They utilise the standard R33GTR rims (what I have on mine). They are 17 X 9 X 30 offset with 245/45/17 tyres."
Does the rim manufacturer matter so much if you have a larger offset? I thought this is what helped with the caliper clearance on the brembo's. I'm looking at a couple of different options, Enkei rp03's if I can find them or maybe a set of rp05's if they aren't too exxy.
The works rims have factored in a little too just waiting to hear on the above.
Was thinking of going for 19" 9.5 +30 offset. What profile tyre and manufacturer/brand are you running?
Does the 19" make it much harsher to drive or are they still good for giving a bit of stick around the mountains? 18" with the profiles I mentioned earlier are smooth as, very direct in the steering and just great overall in the handling... that is until you find a really tight corner and the ass starts to pull before you put your foot back into it - the extra weight through the rear and longer wheel base has nearly brought me unstuck a few times so I just want to be sure I'm not going to mess with the handling if I go 19" rims.
Oh and for anyone who wants to know where I'm getting my numbers from, I should credit the source, the calculator is from here: http://www.kouki.co.uk/utilities/visual-tyre-size-calculator
I put SydneyKids number in to see what they came up, same as the stock C34 pretty much.
rolling radius 204.93 cm total diameter 65.23 cm Sidewall height 11.03 cm
Ignore the offsets of that sydneykid has quoted. His car is a auto which has a 50mm wider rear cradlle in it than your 260rs.
If you were to run the wheels you listed 19x9.5 +30 they will not fit in the rears as they will hit the struts.
If you want to keep your wheels inside the rear guards with minimal rear camber go no wider than 9.5 with around +12 offset
Some people on here have different ideas (MIKE and myself for example) to what fits and what they think looks good etc. so you will not get a exact answer to what fits
Let us know how you want the rims to sit, what camber you want to run, ride height and tyre size and then we can give you a better idea as to what "fits"
so your telling me, r34 gtr wheels will NOT fit on a manual s2 stagea due to the rear wheels hitting the struts?
No
GTR rims are 9" wide not 9.5" as quoted above. They will have a bit more clearance
They will be close, depending on what struts you have and what camber you run
No
cool cool will have to fit them as soon as i get my car
they are 18x9 +30 i think....
I've taken off one of my rims and have taken some measurements of what I had.
The 18" rim is 9" wide, the offset is stamped on the inside as 38.
I was thinking of going 9.5" but am starting to think sticking with a 9" would be better to save on weight on the rim and the extra rubber.
Not sure if I worked out the ride height correctly but from the centre cap I measured from the floor to the top of the wheel arch which was 27", from the floor to the top of the wheel it measured 24.5" (the last figure could be out a little as I didn't have something flat to stick on top of the wheel to put against the measuring tape.
From what I was told going +30 offset on a 9.5" rim would hit the suspension, that appears certain given the extra .5" is close to 13mm which together would make 43mm total (7 more than the 38 I already have).
So If I get a 9" and go for a +30 offset what difference would the 8mm less have overall to whats currently fitted. I noticed the rear rim is inset more to the outside of the guard and with the front I guess a lower offset would bring this out another 8mm closer to the guard. I haven't read up on the camber parts of the equation but would imagine that 8mm difference could pose an issue if it was to rub on the outside of the front guard.
I really should read up more on this stuff and not rely on other people to help with this, thanks to all who have contributed thus far. I just want to be certain I'm not going to be ordering the wrong rim as I'm sourcing these from a supplier in the US who seems to have a good stock of enkei rims which is now certain I'll be getting as all the other brands are made to order with a 10-12 week delay.
Doesn't look like a 9" is available in the rim I'm looking at getting.
Found this website which only has 8.5" and 9.5" sizes available in the Enkei RP03.
http://www.stillen.com/product.asp?id=ENKE...;c=WH&m=all
The smallest offset number is 22 which given then extra .5" of rim would make it 35mm when compared to the 38mm I had.
Have I worked this out right? Looking at ordering the rims this week if everything checks out okay.
Edited by CruisingFast
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
