i have 3 auto meter gauges sport comp, that are not needed any more
boost oil press and amps
oil and amp ones have chome cups have very litte bit of rust on thim not bad. and thay are gauges only, thay come of my vl.
and boost has no cup all wires and fittings are there as it was in my skyline
looking for round $150? for thim all
will post no worrys
pm or call/msg chris 0406073596
https://www.sau.com.au/forums/topic/328194-3x-auto-meter-gauges/
