hey guys up for sale is an ARC radiator off a r34 gtr (not sure what other models it will also fit)
it has sum bent fins, but otherwise is in perfect working order. had it pressure tested today to make sure prior to selling :D
$400
located in sydney, you can contact me on 0406 648 882
pick up preferred but will post at buyers expense :)
Edited by QUICKY
https://www.sau.com.au/forums/topic/328748-r34-gtr-arc-radiator/
