Hey guyz, just getting the Autowatch 446 basic Alarm installed in my car for now. Coz i am low of Cash. Will Upgrade it later.
Wanted to know if its good or not? Is there a big difference between the 446 basic and premium model apart from the extra sensors?
Some questions bout the Standard 446 alarm
1. Is the basic one Aus standard approved? getting insurance with Just Cars so need one that is approved.
2. Does it have a Siren?
3. Does it come with any sensors in the package?
4. does it have anti hijack coz Autowatch site says it does but when i called Action alarms they sed no.
Please help guyz...
Cheers,
Vish.
https://www.sau.com.au/forums/topic/328750-is-the-autowatch-basic-446-good/
The 446rli alarm system is a good reliable all round alarm system which is Insurance approved, it can be an immobiliser only or an alarm as well. The sensors you get depend on the company supplying the product and what they offer with each package. If you car is turboed then you won't be able to arm the alarm while a turbo timer is running, only the doors will lock/unlock. You would have to wait for the engine to shutdown before arming the alarm.
The 446rli Standard does not have anti-hijack but it does have keyguard.
The 446rli Premium is more suited if your interested in hijack and you can arm the alarm and lock doors while the engine is still running, you can also stall the engine via remote before the turbo timer times out at any time while walking away from your car.
Cheers, :/
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
