  • Replies 329
Posted Images
Hey Michael, yes there definately will be sign up forms there on the day! Alternatively, you are more than welcome to use our brand new online application form!
http://japan2011test.downsouthlan.net/inde...t&Itemid=27
Done,
submitted form!
Cheers
I've just made the bank transfer of $35 for the dyno day. Description for the transaction is "typevu dyno day"
Cool. I'll keep an eye out for it.
Brezza, I have your form. Just awaiting confirmation of payment. :D
Hey Ruby,
did my payment clear?
Brezza, membership payment and dyno day payment confirmed.
Volk34, dyno day payment confirmed.
Aberax, dyno day payment confirmed.
Matty T, dyno day payment confirmed.
Type Vu, dyno day payment confirmed.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
Ă—
Ă—
