hey all im selling the following,
Audio master model – AM4560
4 channel car amplifier, peak music power 560 watts
Rca line imput, bridgeable outputs, front channels, variable gain control, bass select switch 0bd6db12db cross over switch LPF / full/ HPF LPF also variable from 50hz – 300 hz HPF variable from 50hz to 300hz
rear channels variable gain control, bass select switch 0bd6db12db cross over switch LPF / full/ HPF LPF also variable from 50hz – 300 hz HPF variable from 50hz to 300hz
this item is in great condition it was only used in my car for 2 months i sold the car it was in so its no longer needed im only asking $80 ONO im located in perth postage at buyers expense please contact 0402 690 998 for pics and further information :thumbsup:
https://www.sau.com.au/forums/topic/328826-for-sale/
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
