Just adjust your headlights properly and they won't blind other drivers. I have HID's without projectors, used to blind everyone before I adjusted them, now they are fine.
Not worth paying hundreds of $$$ for.
https://www.sau.com.au/forums/topic/328959-hid-retrofit/#findComment-5347056
This is why I want a proper HID fit with projectors... notice how smooth and focus the throw of the light is with projector vs the one without.
The one without, all the light is scattered.
https://www.sau.com.au/forums/topic/328959-hid-retrofit/#findComment-5347066
Again, not worth hundreds of dollars. My HID's are not scattered. There are some slight hotspots close to the car where the light creeps out under the headlight. These photo's are really old and I wasn't really focusing on the HID's, but you can sort of see what they look like.
I would install the HID's with the stock reflectors, then if you don't like them think about paying for some projectors. If you've ever seen R34 xenon headlights, they don't actually have projectors but the spread is still good. Personally I don't think you need projectors for HID's, but having said that I do think the projectors themselves just look classy. Nothing to do with how they throw the light, I just like the look of projector headlights, looks more modern and refined. So I can understand wanting them, my argument is just based on the fact that you don't actually NEED them to have HID's.
Edited by Hanaldo
https://www.sau.com.au/forums/topic/328959-hid-retrofit/#findComment-5347674
" Personally I don't think you need projectors for HID's, but having said that I do think the projectors themselves just look classy. Nothing to do with how they throw the light"
Are you kidding me??
Are you that blind?, did you not see the youtube comparison - hid projector vs stock reflectors?
Perhaps you are lucky with your car with its standard reflector working well with hid, but I would say in the majority of cases, HId kit definitely
need projectors to bring the absolute best out of them.
https://www.sau.com.au/forums/topic/328959-hid-retrofit/#findComment-5348035
Why the aggression mate? I'm offering advice, no need to be offensive.
Did you ever think that maybe that bike just has crappy reflectors, as lots of them do? I've seen plenty of different cars with HID's and stock reflectors that look great, it's not hard to get rid of hot spots. Have you tried installing HID's in your car with the stock reflectors? If not then do it, you won't lose anything and you will be able to see how they look with your cars stock reflectors. If there are hot spots, try eliminating them, it's not hard and in most cases you can get rid of all of them. If you still don't like it, by all means go and spend the money to get projectors fitted.
But whatever, it's your money and I'm blind.
https://www.sau.com.au/forums/topic/328959-hid-retrofit/#findComment-5348120
I am not trying to be aggressive, just flabbergasted by your comments.
Personally for me is quite clear cut whether projectors are needed in a HID setup, each to their own I guess.
I don't want to get into a debate with you on the finer points of whether projectors are needed in HID installation or not, so back to the original topic.
Can someone recommend me a good workshop that can do the proper fittings I have described?
I found a good kit on the net, just waiting to see if someone in Perth can do a proper HID retrofit and I am good to go to order the kit.
"http://www.hidplanet.com/forums/index.php" - good info on HID if anyone is interested
Edited by neon_tetra
https://www.sau.com.au/forums/topic/328959-hid-retrofit/#findComment-5348290
easiest way would be to fit S3 R33 GTR lights, thats if you have a R33 lol. even then you have a to modify them a bit to make them fit...personally i wouldnt bother... ive got hid's on my R33 and no problems...as said b4 adjust them properly
https://www.sau.com.au/forums/topic/328959-hid-retrofit/#findComment-5349467
Hi
Anyone know any good autoelectrician in Perth that can do a proper HID retrofit?
that includes modify lights to fit proper hid projectors so I don't blind other drivers.
Attach is an example of a proper retrofit and just not plug and play.
after having a quick look through that first link u posted - the civic, no autosparky shop is gonna be interested in doing that, its more of a DIY job, u mayyyyy find someone whos willing to do a cashy but it looks like theres a shitload of hours involved (as i said i had a quick look through it) so its gonna be very expensive to pay someone else to do it for u.
i didnt see the comparison vid of the projector vs non projector hids, yes there probably is a big difference between the 2 but for everyday driving normal hids are fine. ive had mine for about a year i drive my car everyday and nearly every night, i havnt even aimed my headlights since ive had the car just swapped the old halogens out for my 6000k bosch hids and ive had no problems whatsoever, i havnt been highbeamd or flashed once so they mustn't be blinding people, not one cop has pulled me over for them - ive been pulled over a few times at night the cop has checked over the whole car and not even mentioned the hids, and i havnt had any problems with visibility there wayyyy better then the factory light ive only ever needed highbeam on country roads (so i see animals and crap like that in the distance)
https://www.sau.com.au/forums/topic/328959-hid-retrofit/#findComment-5352482
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
