Ask the John Bow drive day group. That would cover the insurance problem and I couldn't see a PI track day through them costing more than 600 a head.
If you wanna run this day as a birthday I really hope you are loaded and you plan on paying for everyone!
I'm in to racing my car more than any thing else in the world,
but theres no way i'd be handing over 600 bucks of my hard earned for a day like this...
and i certainly wouldn't pay 600 bucks to go to a mates birthday, even if it was racing at the island.
Just hire out a house at the island for the weekend, do a normal track day and then get really drunk afterwards :P
Problem sloved...
I'm really intriuged by the sudden influx of people jumping on here thinking they can just organise a track day.
Its way more expensive and way harder to run/organise than you think.
I know you think you understand what it takes to run a day like this, but listen to what people are saying... you don't!
but yeah, good on you i spose for giving it ago...
  • Replies 41
Just hire out a house at the island for the weekend, do a normal track day and then get really drunk afterwards :D
Problem sloved...
cool thanks i guess mate
i have a few options to look into
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
