BRAND NEW RDA R34GT-t clutch kit which I thought I needed but turned out I didn't , this kit has a EXCEEDY friction plate so you know it's aquality item.
Being sold at way below cost , price now reduced to FLE- Ebay http://cgi.ebay.com.au/NISSAN-SKYLINE-R34G...=item1e5d1bff5a
The clutch is at Helensvale/Surfers.
clik pic once to enlagre clik again to supersize.
RDA PART No RDC 2364N
Will swop for something usefull to me like a satnav, rotors for a BMW 318is, Clutch kit for a BMW 318is, - any usefull stuff considered.
Edited by BASHO
https://www.sau.com.au/forums/topic/329264-r34gt-t-clutch-kit/
hello mate
unable to sent u pm
give me lowest you can sell it for? and if you can send me pm total delivered to Republic Georgia !!
Thx
hello mateunable to sent u pmgive me lowest you can sell it for? and if you can send me pm total delivered to Republic Georgia !!Thx
Here you go with a link to the Australiapost postal calculator the kit weighs 10 kg and measures in mm 320x330x100.
http://auspost.com.au/index.html
The clutch cost me $500.00 on a group buy so make me a reasonable offer.
Looks like abouts $242.00 for the postage but theres options regarding insurance as well so let me know if your still interested.
Just FYI I have been told that there is no Austpost economy airmail anymore.
Edited by BASHO
  • 3 weeks later...
Hey Mate,
Can you give me some more info on this ? or point me to a website that has more details or even the link from where u got the group buy etc..
Is it a standard replacement, how hard is its clamp load ?
Just looking for a replacement clutch for my car, my mechanic told me I have about 15,000 ks left on mine..
Thanks.
Paul.
Hey Mate,
Thanks.Paul.
Hi Ho Paul,
I bought this on the back of a group RDA & EBC pads rotors buy on here about 9 months ago, it's a new standard replacement pressure plate with new thrust bearing and a new Exedy organic clutch plate .
Here is the link to the group buy- http://www.skylinesaustralia.com/forums/Rd...html&st=420 -this should take you to the page where my payment is acknowledged theres about 20 pages in the topic I'm in a few of threm.
The part No is above perhaps if you phone RDA and quote it they can give you more info.
I've sold the R34GT-t and don't need it--I'm driving a Beemer now, not sure it was a good move , it's hard to adjust when there's no ummph here we go at 3000.
Cheers,
Al.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
